New Idler arm has no zerk #1065809 11/02/13 07:21 AM
hochkis Offline OP
So i bought a new idler arm for my 95 SR, it has a zerk fitting in the upper 'bushing' portion but none around the ball joint and there doesnt appear to be any grease in the ball joint.
Can I just carefully drill through the back of ball joint and add a zerk fitting there? or should i go through the side like on the pitman arm?
95 Montero SR- Stock
90 Turbo Miata - TD04 wrx turbo, Flyin miata suspension, Torsen diff, 225 RS3's
92 Mighty Max 4x4 - Retired
Re: New Idler arm has no zerk [Re: hochkis] #1065810 11/02/13 11:53 AM
I just looked at my new one, sitting on the dining room table, and noticed the same thing. No, I was not sitting on the table, the idler arm was.
As far as I remember, the only zerk I've seen on those has been on the body itself. I guess you could add one to the ball joint portion, but they usually wear out in the shaft part anyway.
Did you get a part with a "lifetime warranty"? If so, just replace it every year or so like I do.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5878 MB (Peak: 0.6358 MB) Data Comp: Off Server Time: 2026-05-30 05:55:05 UTC
