Page 3 of 4 1 2 3 4
Re: Meet my Gen 1 [Re: captainawesome] #1065919 03/06/14 06:56 PM
captainawesome Offline OP
I am finally getting around to ordering parts and getting started on the long overdue maintenance items. I replaced the windshield washer pump, wipers front/back, and a new gas cap yesterday.
Today I ordered the following:
idler arm
OEM rear axle seals
heater motor resistor
new v-belts and serpentine except timing
OEM fuel filler hose
On my lunch today I want to start knocking out items that only take sweat equity while waiting on the parts.
weld hood latch notch
clearance front driver tire rubbing
grease/lube driver rear door lock linkage
grease/lube sunroof track
grease/lube rear lock, keyhole, and linkage
adjust e-brake
I've also been thinking about running a motorcycle hitch hauler for bike projects. Unfortunately my receiver setup is only 1 1/4". I am sure most are setup for 2", and I want it to obviously be safe enough. Anyone know of a good solid aftermarket receiver that will bolt up to the stock location? Would it be able to handle a 400 lb. motorcycle?
Something like this: motorcycle hauler
1990 Montero LS LWB A/T
1989 Montero LWB 5 spd
Re: Meet my Gen 1 [Re: captainawesome] #1065920 03/06/14 07:16 PM
For a receiver, keep your eyes open in the Junkyard. I got one off a four door that was 2" and pretty much bolted up to my 2 door.
Re: Meet my Gen 1 [Re: Mudraider] #1065921 03/06/14 07:26 PM
Unfortunately they are like hens teeth around here. I've only seen one in the past few years, and had I know at the time, would have taken way more spare parts.
Re: Meet my Gen 1 [Re: captainawesome] #1065922 03/06/14 08:35 PM
stevec Offline
I have the same question. I really want to put a 2" receiver on my 1990 LWB. I see this one, which looks tantalizingly like it would fit my truck:
http://www.amazon.com/Curt-Manufacturing...937&sr=8-11
But all of the text says that it won't. I don't know whether that's a statement about the bolt placement or perhaps that it doesn't clear the bottom of the stock bumper? They point me to this one instead:
http://www.amazon.com/Curt-Custom-Class-...3937&sr=8-6
Which is both 1.25" and more expensive. Has anyone ever tried the 13091 on a pre-1992 vehicle?
steve
90 LWB Montero, 3.0 V6 EFI SOHC, MT, original owner
Re: Meet my Gen 1 [Re: stevec] #1065923 03/06/14 08:58 PM
I have that Curt hitch. It'll fit both a Gen 1 and 2, but since my '86 doesn't have a rear bumper on it, I don't know if it clears.
Re: Meet my Gen 1 [Re: stevec] #1065924 03/06/14 09:42 PM
steve
I found this link interesting about the Curt hitch 13091.
Curt Hitch
If the measurements are correct, I can't see any reason why it wouldn't clear the bumper. It would only raise it just slightly higher than my current receiver, and it has at least an inch clearance. I am probably going to order it soon and see.
Re: Meet my Gen 1 [Re: captainawesome] #1065925 03/06/14 09:43 PM
PartyTruck Offline
Just cut the 1 1/4" away and weld (or have someone you know weld) a boxtube with a 2" inner diameter in there instead. Drill the hole for the pin and bobs your uncle.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: Meet my Gen 1 [Re: PartyTruck] #1065926 03/06/14 09:54 PM
Thought about that as well. It's still an option, but I would have to have my buddy weld it up for me. I don't mind doing the light duty stuff, but hanging a 400 plus pound bike off of it is more than I want to risk. The Curt unit looks plenty beefy enough as is.
Re: Meet my Gen 1 [Re: captainawesome] #1065927 03/06/14 10:14 PM
Found this link as well.
http://www.4x4wire.com/forums/showflat.php?Number=1225815
My receiver sticks out past the bumper and down though. Maybe I need to look at it a bit more and see what's going on there.
Re: Meet my Gen 1 [Re: captainawesome] #1065928 03/07/14 02:20 AM
PartyTruck Offline
If you and your friend are up for a litle cut 'n weld you could make a new plate to mount to the frame with the 2" hitch tube passing through it. There should be a circular hole in the center of the frame mount that you can cut out as a square for the hitch reciver to drop into giving it more support.
I did this on my gen 2 and welded everything to the frame. Downside is that if you tow low built trailers you need a hefty drop to keep it level and that puts some of stress on the frame.
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.012s) Memory: 0.6479 MB (Peak: 0.7573 MB) Data Comp: Off Server Time: 2026-07-14 12:36:29 UTC
