Re: Dodgy 4x4 T-case switches [Re: plh] #1066322 11/18/13 10:45 PM
There is a version ASA that has been built to work with Virtual PC on a Mac. I have it, works great. Let me know if you want it and I'll put it somewhere so you can grab.
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Kudos!!
Anyone come up with one that will run on my iPad or an Android tablet?
Re: Dodgy 4x4 T-case switches [Re: off-roader] #1066323 11/19/13 03:06 AM
plh Offline
Kudos!!
No Kudos to me. Another member here built it for me, but I forget who!
Can't really host it on a site as its an entire VirtualBox ROM of XP along with ASA. Only way he could get it to work from my understanding.
PM me for details.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Dodgy 4x4 T-case switches [Re: plh] #1066324 11/19/13 03:44 AM
plh Offline
Kudos!!
PM me for details.
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: Dodgy 4x4 T-case switches [Re: off-roader] #1066325 11/21/13 06:11 AM
V
vectorsc Offline OP
Okay. So these switches are fully cleanable. Fill em with your cleaner of choice and go!. Test with a multimeter to verify operation and have fun!
1999 Montero Gen 2.5
Re: Dodgy 4x4 T-case switches [Re: vectorsc] #1066326 11/21/13 08:02 AM
Vector, can you elaborate? What did you do and what were the results (although I can deduce it, I'm trying to coax you to help others).
Re: Dodgy 4x4 T-case switches [Re: JohnnyBfromPeoria] #1066327 11/21/13 03:33 PM
V
vectorsc Offline OP
-Remove the connectors from the harness block using a flat head micro screwdriver
- one at a time for this step...
-use a 22mm wrench to remove the switch.
-I then filled the switch from the bottom with cleaning agen
-actuate the switch a few dozen times against a paper towel and watch all the crap start coming out.
-test for continuity with the multimeter.
- repeat until the ohm meter reports 100% ok.
I used strike hold electronics/gun cleaning stuff for this. Use whatever agent you do at your own risk as it may eat the inside if your switch. Make sure you get it all out so you don't fubar your tcase oil.
Re: Dodgy 4x4 T-case switches [Re: vectorsc] #1066328 11/21/13 03:55 PM
Wow, thanks. Good job!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6287 MB (Peak: 0.7218 MB) Data Comp: Off Server Time: 2026-06-07 05:59:32 UTC
