Re: Hi new member and looking for sugestions [Re: off-roader] #1066351 11/20/13 01:48 AM
Monteropr Offline OP
i think i found my 4.90 donor!!!
Re: Hi new member and looking for sugestions [Re: Monteropr] #1066352 11/20/13 04:28 PM
You need to do some cross checking on the MS 4.90s going into an earlier Gen II Montero. Yours likley has the smaller axles than the later 1990s and I'm not sure the MS's R&P will fit.
Similalry, the Aussie 3.15s were for the later Gen II's bigger t-case. You'd be looking at 2.85s old style, or the now "common ratio" 2.70s.
Re: Hi new member and looking for sugestions [Re: Monteropr] #1066353 11/20/13 05:34 PM
If the terrain is anything like Panama, I wouldn't waste time with the LSD in the front. Panama was really muddy and slick. I'd weld the front diff and put on some manual hubs, check with plh and his manual hubs . Locked wheels on terrain like this is so much better.
Re: Hi new member and looking for sugestions [Re: Monteropr] #1066354 11/21/13 12:01 AM
ryany Offline
The front diff housing from the Montero Sport won't fit the Montero due to some minor differences, you'll have to swap over all the guts or just the R&P to your existing diff housing.
95 Montero SR
Re: Hi new member and looking for sugestions [Re: ryany] #1066355 11/21/13 06:24 AM
Angelo Offline
What years & which vehicles were the 4.90's available. May need a front set soon.
Funny thing is that when I originally bought them, I think the parts guy told me it was listed as a Gen III gear??
Re: Hi new member and looking for sugestions [Re: Monteropr] #1066356 11/21/13 07:28 PM
You are clearly no stranger to building old rides. Any chance you could poke around and see what is in the yards in PR for an old 2-door with the convertible j-top setup?
Re: Hi new member and looking for sugestions [Re: ryany] #1066357 11/21/13 11:09 PM
yeah, i talked to the owner, he said i was not the first one to drop by his junk yard looking for a 4.90 RP, and he asked if i knew there was a 5.something, but he said it needs to be imported from Australia ((he had 2 trucks from there, but axles were gone)) he said this is an easy swap, just swap the RP only according to him, since right now i'm in the middle of another project, i have finals as well and Christmas is here, i left them in reserve, i will leave these upgrades to work on next year, I will do the 2.70 t-case upgrade, got to talk to mark and friend of mine is gona help me do the swap, ausier loocker, still thinking about it, that welding idea is tempting, but ebay has the ausier locker in 200 bucks, not sure if mark has them too, i had a bad experience welding gears the last time i did that jajaja, oh noooooo, bad times bad times and the gears, well there mine, he said go pick em up, whenever...
on the other hand, i wanted to show u guys what im working on this december... wana make it run by new years
http://www.4x4wire.com/forums/post-images//1285532-Capture.GIF
also i mentioned i build headers for my truck, and i blew a header gasket so i will try to change it this weekend and ill take pictures see if any of you guys might want to build one for yourself, i did it with some spare tubing, came out well, will post when i fix that. MontyMcV ill check ur request,
58 (283) Corvette top flight
67 (427) Corvette top flight
69 (302) Camaro
70 (440) Chevy
36 Dodge Brothers Hot Rod
30 Ford Hot Rod
07 Dodge Ram STR
93 Montero
Re: Hi new member and looking for sugestions [Re: Monteropr] #1066358 11/22/13 07:05 AM
Angelo Offline
Looks like you've def done your research and moving along nicely. Keep it up. I'd like checking out fab work
Re: Hi new member and looking for sugestions [Re: Monteropr] #1066359 11/22/13 01:19 PM
Wow on the 429 build!
PHP: 7.4.33 Page Time: 0.008s Queries: 17 (0.005s) Memory: 0.6365 MB (Peak: 0.7572 MB) Data Comp: Off Server Time: 2026-06-07 09:06:13 UTC
