Looking for East coast SR 3.5 engine
#1066360
11/18/13 10:35 PM
Anyone selling or know where to grab a 3.5? I guess I can do a Diamante SOHC. Found lots of talk about the swap in the archives but didnt see any with real info or threads were someone did it. Not sure if I can use the diamante block and my heads or stick with the SOHC. If I do SOHC what do i use for intake, engine mounts, timing covers etc..?
Machine shop quoted me $1500 in just parts to redo the block <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Looking for East coast SR 3.5 engine
[Re: mitsumonki]
#1066361
11/18/13 10:43 PM
Machine shop quoted me $1500 in just parts to redo the block <img src="/forums/images/graemlins/confused.gif" alt="" /> Did you try checking car-part.com for a block?
[Re: off-roader]
#1066362
11/19/13 01:28 AM
Which one should I look for? Diamante might be cheaper but will DOHC heads work? Got a quote for $1300 for a whole used DOHC.
[Re: mitsumonki]
#1066363
11/19/13 01:32 AM
IIRC, a diamante engine uses different cams that are tuned differently (less torque iirc) plus the dipstick may be on the wrong side. Others here can confirm that since I've only read about this swap.
[Re: off-roader]
#1066364
11/19/13 03:16 AM
I have an SR motor pulled from a running truck I was planning on installing in my Raider, but I decided to go GM power plant. I might be too far away, but Id take 1k for the entire engine.
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: mitsumonki]
#1066365
11/20/13 04:23 PM
You need to clarify 3.5 DOHC or SOHC...
[Re: StockRaider]
#1066366
11/20/13 05:22 PM
I have an SR motor pulled from a running truck I was planning on installing in my Raider, but I decided to go GM power plant. I might be too far away, but Id take 1k for the entire engine. Don't go GM, look at all you'll have to change.
[Re: Mudraider]
#1066367
11/20/13 06:12 PM
The trans overheats, the transfer case is worn to the point the chain rubs against the case, and th engine is a oily lump. Body is coming off the frame after my buddy's tranny swap. And it's getting done up <img src="/forums/images/graemlins/smile.gif" alt="" /> But yea, the engine I have is from a 95SR DOHC 3.5
