Page 3 of 3 1 2 3
Re: truck hates the cold. [Re: dirtnapper] #1066501 12/14/13 02:34 AM
cheesegrater Offline
Hate to say it, but sometimes we just have to bite the bullet and call a shop and have the hoopty fixed. At least it'll be inside someplace and maybe it'll start.
Re: truck hates the cold. [Re: cheesegrater] #1066502 12/15/13 08:29 AM
dirtnapper Offline
That could be a possibility in the next week. Before heading to work today, I gave it one more try. Just cranked it over and it started. But it seemed as soon as I stepped on the gas pedal it would not rev up at all. It just bogged out and died and wouldnt start up again. So im guessing carb problem of some sort. Im going to take the carb from the other raider and swap them around.
Re: truck hates the cold. [Re: dirtnapper] #1066503 12/15/13 12:11 PM
Have you checked the fuel filter?
Re: truck hates the cold. [Re: cheesegrater] #1066504 12/16/13 12:51 AM
Have you checked the choke as closed on a cold start? To get the chooke to close, you have to press the gas once. On my old 2.6 carby, in really cold stuff, you had to pump the gas 3-4 times to get enough gas in there for enough cold start enrichment, and even then, it would stumble for a while until it warmed up some.
Also test the ecu engine coolant temp sensor as that also affects cold start enrichment via the duty cycle of the mixture solenoid vavle in the carb.
Re: truck hates the cold. [Re: fasteddy] #1066505 12/16/13 02:18 PM
powerRam50 Offline OP
now that i am running a lower rad hose heater and if its really cold a mag oil pan heater it starts up just fine. and yes not in eugene.moved to laramie wyoming for a year for wyotech.just got here in july.
Re: truck hates the cold. [Re: powerRam50] #1066506 12/17/13 05:13 AM
TainterRacing Offline
Mine this morning (-12F) started but I was not sure it would.. I think I need to get some lighter weight oil in it has 10w here will go with 5w I think.
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: truck hates the cold. [Re: TainterRacing] #1066507 12/22/13 07:32 AM
dirtnapper Offline
Thanx to everyone who replied and to the OP sorry for thread jacking...
Anyways its up and running again. New starter is a beast, the problem was that the cable to the carb wasnt connected. A buddy came over and watched the carb while I was pumping the pedal. Nothing was moving and it just wasnt hooked up properly. I also did replace the fuel filter last month also.
Re: truck hates the cold. [Re: dirtnapper] #1066508 12/22/13 06:45 PM
glad its running
Re: truck hates the cold. [Re: powerRam50] #1066509 12/24/13 02:51 AM
METALMOVER Offline
Might want to unhook it, it was a high of 9 today and my wife says to me, do you think the Raider will start? I said of course why? She says well it heats up a lot faster and is way easier to park, needless to say its shopping right now. METALMOVER
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6319 MB (Peak: 0.7190 MB) Data Comp: Off Server Time: 2026-07-17 00:46:52 UTC
