dual battery setup 1 gen lwb montero
#1066565
11/24/13 06:03 AM
my land cruiser had duel batteries and i loved having that extra battery and want to do the same with montero. i know how to do the wiring but i was wondering if anyone else has this setup and where they put the extra battery?
1990 5sp lwb 274,000 miles 80,000 on new motor
Re: dual battery setup 1 gen lwb montero
[Re: 1morebike]
#1066566
11/24/13 07:21 AM
I don't recall if yours is and RS or LS model. Either way, the second battery mount location is on the driverside front inner fenderwell immediately behind the headlight. On the LS, this is where the headlight washer reservoir is located. There may also be interference from other items.
Others will chime in.
[Re: rxinhed]
#1066567
11/24/13 07:48 AM
no headlight washers so i should be good. is there battery box people are using?
[Re: 1morebike]
#1066568
11/24/13 04:24 PM
gen 2 battery tray fits nicely.
a/c lines and cruise control unit will also be in the way - if you have those. I tried this mod, removed the hw pump, and then ran into the other items. There are good threads on this...
[Re: Oso]
#1066569
11/25/13 02:21 AM
I did it, it is great and a cheap build,
I bought a boat battery box, a jumper cable removed the clamps and welded the worked very good main battery is in engine bay, the other is beside the driver seat
I have pictures if you like
58 (283) Corvette top flight 67 (427) Corvette top flight 69 (302) Camaro 70 (440) Chevy 36 Dodge Brothers Hot Rod 30 Ford Hot Rod 07 Dodge Ram STR 93 Montero
[Re: Monteropr]
#1066570
11/25/13 10:39 AM
Of course we would like pictures. Thanks.
[Re: Oso]
#1066571
11/30/13 05:07 AM
a/c lines and cruise control unit will also be in the way - if you have those. I tried this mod, removed the hw pump, and then ran into the other items. There are good threads on this... no cruise but i do have ac...it might fit but it will be tight, ill let you know.
