redline mt-85 worth it #1066790 11/30/13 10:08 PM
1
1morebike Offline OP
about to spend $80 on some redline oil for the transmission ans transfer case just wondering if anyone has used it and if it made a difference?
1990 5sp lwb 274,000 miles 80,000 on new motor
Re: redline mt-85 worth it [Re: 1morebike] #1066791 12/01/13 12:23 AM
plh Offline
Stick with Pennzoil Syncromesh, and being you have a 5VMT1, make sure you also put in the Mitsubishi MT additive. Helps the syncros shift smoothly.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: redline mt-85 worth it [Re: 1morebike] #1066792 12/01/13 12:57 AM
KrzyDav Offline
I have had MT 1 Redline in there for about 5 years,,,but not many miles on it.
Slow secros on 1-2 are just something this trans has. Some must of been worse than mine because they had a kit for the 90-91. Slow syncros are a small price to pay having for this very H. D. trans.
I've used Stalube 80 with a little LSD juice, it worked good.
Used synchro too.
Down side to Redline is it seems to evntually eat silicone used on for trans gaskets, IMHO.
dave h.
Re: redline mt-85 worth it [Re: KrzyDav] #1066793 12/01/13 01:50 AM
1
I have read the mt-85 helps with syncros. I also know about synthetic making seals leak so we will see. I don't think it's going to make things worse so I guess I'll give it a shot, my hope is that it helps when the truck is cold.
Re: redline mt-85 worth it [Re: 1morebike] #1066794 12/02/13 09:03 PM
P
pcc Offline
You won't know it's worth it unless you do a used oil analysis on present (other) oil then one on Redline. You'd then have to attempt to extrapolate the results over the number of miles you drive to see if the money spent is worth it in your mind.
Re: redline mt-85 worth it [Re: pcc] #1066795 03/23/14 05:34 PM
1
to answer my own question its totally worth it, i used the mt-90 and my transmission feels 200% better. i just order more for the t-case
Re: redline mt-85 worth it [Re: 1morebike] #1066796 03/24/14 02:57 PM
Malykaii Offline
I like stuff like that in the tranny and feel its worth the money... however the transfer case has no synchros or what not so i dont think you'll feel any difference there.
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
Re: redline mt-85 worth it [Re: Malykaii] #1066797 03/24/14 03:00 PM
Malykaii Offline
Regarding leaks. Synthetic has smaller molecules or something like that, so it is more likely to leak through a weak seal than conventional. So if you didnt have any leaks you shouldn't have any now unless any seals are just barely holding up. The notion that synthetic causes leaks isnt true.
Re: redline mt-85 worth it [Re: Malykaii] #1066798 03/24/14 04:22 PM
1
the fem says to use gl-4 in the t-case. the other thing that noticed after putting the mt-90 in the tranny was a lot less gear noise, thats the main reason of adding it to the t-case plus who know what the pm put in there.
Re: redline mt-85 worth it [Re: Malykaii] #1066799 03/24/14 10:41 PM
ryany Offline
Correct. Dino oil molecules are long chains, where the synthetic oil molecules are much smaller. A marginal seal or gasket can hold dino oil but can leak synthetic oil with no other changes.
95 Montero SR
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6370 MB (Peak: 0.7607 MB) Data Comp: Off Server Time: 2026-06-19 06:45:06 UTC
