33x12.5 x 15 inch Tires for my 89 swb v6?
#1067066
12/13/13 12:03 AM
My 89 v6 is a 5 speed manual and has the #4625 axel. No Limited Slip
Been running 31x10.5's forever! Thinking of trying 33x 12.5 Goodyear Duratracs - any comment?
Pro Comp XAT 32x11.5's are also an option
89 V6 SWB OEM Sunroof RPW Headers & Custom Exhaust 15" Toyota 4Runner Chrome Rims 33X12.5 Goodyear Wrangler Duratrac Stainless Steel Lugs
85 2.6 Montero (RIP) <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: 33x12.5 x 15 inch Tires for my 89 swb v6?
[Re: Bubba]
#1067067
12/13/13 01:50 AM
Pro Comp XAT 32x11.5's are also an option IT's in the FAQ but I see you're not on here that often so you probably missed that. 33's will fit with a 2" BL (4crawler.com makes them). You'll need to trim the rubber end caps on your front bumpers and probably torque your torsion bars. Oh, and most shops won't mount them on the stock rims so you may need to upgrade to wider rims.
[Re: off-roader]
#1067068
12/13/13 02:53 AM
I run them on my '88. 2" rear OME leafs, you could probably get by with the rear coils from a Gen 1 LWB, front torsion crank to level. Non-stock front bumper or trim the ends on stock one slightly. 8 1/2" wide wheels.
I did run them on my '88 for a year prior to the suspension lift, but they occasionally rubbed a little.
- '83 Might Max: IG @83mmax
- '88 Raider: my OG
- '89 Raider: rescued
- '92 RS M/T: sold
- '93 SR: sent to crusher
- '05 Montero LTD: sold
- '18 PHEV: wife's daily
- '14 OL GT
- http://www.tuffpans.com
[Re: Bubba]
#1067069
12/13/13 03:13 AM
2" BL with home made bumpets. No TB twist 4 door SR springs in rear gave a good 2" of lift ![[Linked Image]](http://i598.photobucket.com/albums/tt64/fastfoodvw/The%20Ram/20131128_080756_zpsbd730e4a.jpg)
[Re: Mudraider]
#1067070
12/13/13 04:06 AM
4x4 Wire Tire Thread 33's will fit on a stock, unlifted Mitsu. See pics in the referenced thread.
[Re: rxinhed]
#1067071
12/13/13 05:41 AM
Hey Russel,
Thanks for that link....I remember reading that a long time ago.....thought there'd be some newer info.
Right, so 33's will fit...but 12.5's will rub depending on the off set of the rim...right?
I'm running 89 Toyota 4Runner 15 inch rims...I'll have to check to measure how much clerance I have with the 10.5's on there now.
[Re: Bubba]
#1067072
12/13/13 06:16 AM
Simply trim the front bumper ends and push the sheetmetal along the interior front edge of the front wheel well out of the way. I used 8.5" wide rims in front and 10" in the rear and did not have rubbing issues over the course of about 40K miles with a mixture of used all-terrains and brand spanking new muds. I have other photos to share off board if you like, as I've polluted on this topic often.
[Re: rxinhed]
#1067073
12/13/13 05:05 PM
My SWB is 33x12.50x15 BFG ATs, 1" BL, 0" SL (maybe some t-bar for leveling), no bumper end caps, no idea offset on 8" steelies, no rubbing anywhere...
[Re: MontyMcV]
#1067074
12/13/13 08:00 PM
Hey Monty, Thanks for the reply. What's "1" BL, 0" SL"? I'm more worried about the 33's rubbing the frame
Is your rig a V6? With the 33's what have you noticed with your performance and gas milage?
[Re: Bubba]
#1067075
12/13/13 08:21 PM
BL = body lift
SL = suspension lift
You "might" get a little rubbing on the inside of the rear tires in the rear, right at the top where the pad for the body sits on the frame. I know that happens with my leaf sprung 4-cylinders, but I don't know if it will affect yours. It's very minor.
By the way, I have 33z12.5-15's on Gen 2 7" wheels on one of my two doors and they do pretty well. Little rubbing up front at steering lock, like when I take a hard right out of a declining driveway onto the street. More noise than anything else.
