Re: Do they make metric (BPT?) to NPT air line fitting converters? [Re: off-roader] #1067178 01/08/14 06:19 AM
off-roader Offline OP
Grrrr it's neither BSPP or NPT! It's just a tad smaller than BSPP so the BSPP to NPT adapter I bought won't even fit in the hole!
Just so were on the same page, this compressor is the bigger brother of the popular MV50 compressor.
Any ideas on what size threads this fitting actually has?
I was thinking as a last resource I will keep the fitting on the compressor and instead cut the end of the rubber hose attached to it and put standard fittings air into the end.
TIA!
Re: Do they make metric (BPT?) to NPT air line fitting converters? [Re: off-roader] #1067179 01/08/14 04:50 PM
Canyonero Offline
Ray,
I've got a similar compressor with the same issue (Masterflow MF-1050) which has it's own proprietary connectors as well, and adapters won't work. From what I've read so far, the only way to remedy this is to tap the head to accept an NPT fitting to use standard hose connections for both the output, the gauge (should you want to replace it, mine is junk) and the intake filter. I'm going to be trying this soon on mine as my hose is starting to show some wear, and could be a tad longer. Along with some other mods to help it run a bit cooler.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: Do they make metric (BPT?) to NPT air line fitting converters? [Re: Canyonero] #1067180 01/08/14 05:50 PM
Yeah that works for the mf1050 but that's not easy to do on this unit because the air chuck is not right at the compressor head. Instead there's a pipe attached to the head along with a heat shield surrounding it that you use for the handle. (See image below)
Unfortunately the pipe is pretty thin walled and I'm not sure you could resize the threaded hole any bigger without compromising the port's physical integrity. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Do they make metric (BPT?) to NPT air line fitting converters? [Re: off-roader] #1067181 01/08/14 06:12 PM
monte3 Offline
This is why JB weld was invented... <img src="/forums/images/graemlins/smile.gif" alt="" />
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
Re: Do they make metric (BPT?) to NPT air line fitting converters? [Re: monte3] #1067182 01/09/14 05:08 AM
Ended up taking the fitting off the end of the rubber hose and replacing it with a standard US fitting. Also replaced the rest of the air lines that came with the unit with a higher quality polyurethane hose and standard quick disconnect fittings. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6120 MB (Peak: 0.7103 MB) Data Comp: Off Server Time: 2026-06-07 08:35:46 UTC
