1995 SR Parts Needed #1067512 12/24/13 08:16 PM
Torchwood Offline OP
Replacing the timing belt on my 1994 Montero SR (3.5L 6G74)and discovered that most of the 10mm bolt holes that hold the water pump to the water pump housing are stripped. Looked in ASA and it doesn't show the part number for the housing that the water pump goes into, only the water pump itself. The bigger 14MM bolts that go into the engine block are fine. Would rather be proactive and have the part available because I figure this will be a problem down the road if I ignore it. Is this a part number anybody has and that I order a replacement for or am I going to have to find one in a junk yard?
Another part I discovered a stripped bolt hole on was the power steering pump, I found the part number for it (MB922960) and this was already on my list of things to replace because it seems to leak oil all over that side of the engine anyway.
Sean - Just a few miles south of Hell, AZ
[color:"blue"]Current Project: 1994 Montero SR recently not smoking, in need of offroad mods.[/color]
Re: 1995 SR Parts Needed [Re: Torchwood] #1067513 12/24/13 09:42 PM
Monty Offline
You can use Heli-Coils
1989 Raider V6/MT
2005 Jeep Liberty CRD Turbo Diesel
Re: 1995 SR Parts Needed [Re: Monty] #1067514 12/24/13 10:11 PM
The ASA part image shows the whole pump set with gaskets, front and back halves. I've bought aftermarket with both, too.
Re: 1995 SR Parts Needed [Re: fasteddy] #1067515 12/25/13 06:31 AM
mxmikie Offline
i have a water pump housing send your mailing address
Re: 1995 SR Parts Needed [Re: mxmikie] #1067516 12/30/13 01:16 PM
mxmikie Offline
pm sent did you get it ???
Re: 1995 SR Parts Needed [Re: Torchwood] #1067517 01/04/14 03:10 PM
mxmikie Offline
hey buddy i sent you a water pump housing did you get it ???
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6097 MB (Peak: 0.6793 MB) Data Comp: Off Server Time: 2026-10-21 22:15:11 UTC
