Page 1 of 3 1 2 3
timing belt broke! #1067654 12/31/13 06:05 AM
1
1morebike Offline OP
i made a post about my montero just cutting out and then nothing. my mechanic did some test and thought it was the distributor,turns out it was the timing belt. i was going up steep hill and at about 3,000 rpms its 1990 with replacement 3.0 engine in it. my mechanic thinks its an interference engine but I'm not sure, am i up a river here? what make me more upset is i have paper work from previous owner showing the timing belt being done 3 years and only 39,000 miles on it. the plan is for my mechianic to do a leak down test and see if the valves are bent.
1990 5sp lwb 274,000 miles 80,000 on new motor
Re: timing belt broke! [Re: 1morebike] #1067655 12/31/13 06:12 AM
It's not an interference engine. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: timing belt broke! [Re: off-roader] #1067656 12/31/13 07:32 AM
Grasscat Offline
Find another mechanic.
Run don't walk.
I'm not joking.
Ray is right,
but find another mechanic.
Do I need to say it again??
Michael j
TreadLightly! Trainer
Re: timing belt broke! [Re: Grasscat] #1067657 12/31/13 08:03 AM
Agree with what Michael said. This is a very common engine found in multiple vehicles so the fact that your mechanic doesn't realize it's a non-interference engine is worrisome.
Re: timing belt broke! [Re: off-roader] #1067658 12/31/13 08:36 AM
No offense to your mechanic. I had a nice guy near me estimate a head gasket replacement on my MM at $1500, after he plainly admitted never working on a Mitsu 2.6L. It seemed to me in the 80s that everything had that engine, as much of what I delivered for auto parts was just that. If the mechanic is a friend, just get him a beer as the Montero is loaded onto the flatbed hauler of your choice and goes to a bona fide shop. <img src="/forums/images/graemlins/zombie.gif" alt="" />
There are things to go wrong if you're not informed beforehand when doing this timing belt job...ranging from the timing belt tensioners to camshaft positioning to harmonic balancer bolt and keyway. This should be a weekend job for an ordinary Joe in the know. A good shop is faster though. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: timing belt broke! [Re: 1morebike] #1067659 12/31/13 04:58 PM
Standard belt replacement interval for that engine is when the belt snaps, no big deal. Put a new one on and drive it until it quits again, should be 100k+ miles give or take depending on the quality of belt used.
Re: timing belt broke! [Re: TOASTY] #1067660 12/31/13 05:29 PM
1
[quote] Standard belt replacement interval for that engine is when the belt snaps, no big deal. Put a new one on and drive it until it quits again, should be 100k+ miles give or take depending on the quality of belt used. [/quote
This is more worry some then my mechanic. The belt on only lasted for 39,000 that's seems awful short
Re: timing belt broke! [Re: 1morebike] #1067661 12/31/13 05:32 PM
monte3 Offline
Until it's taken apart, assume nothing. The belt may have failed because of a bad tensioner, water pump, or <img src="/forums/images/graemlins/confused.gif" alt="" />...
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
Re: timing belt broke! [Re: monte3] #1067662 12/31/13 06:40 PM
mxmikie Offline
maybe he is a boat mechanic..... <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: timing belt broke! [Re: 1morebike] #1067663 01/01/14 03:50 AM
or cam and/or front main leak getting oil on the belt.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 2.604s Queries: 16 (0.004s) Memory: 0.6413 MB (Peak: 0.7654 MB) Data Comp: Off Server Time: 2026-06-13 21:44:55 UTC
