Page 3 of 3 1 2 3
Re: timing belt broke! [Re: pcc] #1067674 01/10/14 10:11 PM
ryany Offline
I'm questioning why the camshaft sprocket was replaced. It's not a wear item and not something that would go bad, unless the shop damaged or broke it in the process of repairs.
95 Montero SR
Re: timing belt broke! [Re: ryany] #1067675 01/10/14 10:53 PM
Oso Offline
as i just found out the woodruff keys are prone to chipping and breaking. could be they broke it trying to remove the harmonic balancer or just found it already damaged. gotta remove the sprocket to change the key. i had to drill & tap mine and use a puller to get it off necessitating a new one.
Re: timing belt broke! [Re: Oso] #1067676 01/10/14 11:31 PM
ryany Offline
The harmonic balancer is on the crankshaft, not the camshaft. Someone would have to be pretty careless to break a camshaft sprocket, they just aren't that difficult to remove.
95 Montero SR
Re: timing belt broke! [Re: ryany] #1067677 01/10/14 11:39 PM
Oso Offline
oops. i misread that as crankshaft sprocket.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6083 MB (Peak: 0.6642 MB) Data Comp: Off Server Time: 2026-06-07 05:59:26 UTC
