ERG valve ? #1067858 01/06/14 11:53 PM
huntnsonvagun Offline OP
Have the weber on the 2.4 liter 87 raider been on there for two yrs now erg light just came on I have the vacuum line on the top of the valve plugged do I need to run this line to a vacuum nipple or is it ok plugged first problem I have had with ERG light coming on also the line that runs out the side I plugged it also it has some moisture build in it when I removed the screw that its plugged with...... I guess my question is do I need to hook these lines somewhere to get warning light off or is plugging them ok...I have removed the erg valve and cleaned it it seems to be fine... thanks for any help
Re: ERG valve ? [Re: huntnsonvagun] #1067859 01/07/14 04:19 AM
Oh my goodness your thread is difficult to read or make sense of. I will try to tackle this one.
1. Have the weber on the 2.4 liter 87 raider been on there for two yrs now.
The Raider engine should be a 2.6L, not a 2.4L which would have FI.
The rest of your post is crap that has no logic. I can't help referring you to board etiquette rules about having intelligible writing: 4x4Wire FAQ Section
<img src="/forums/images/graemlins/zombie.gif" alt="" />
2. I think that you're asking about the little red light that comes on every 50,000 miles, or so. To reset that light, there are two methods. The first is to remove the small cover behind the speedo cluster and trip the small black slide switch. The second is to pull the speedo cluster and pull the bulb.
Your garble I think indicates that you've removed or bypassed the Exhaust Gas Recovery (EGR, not ERG) system, so why would you need the light?
Please organize your text. This isn't Twitter.
Re: ERG valve ? [Re: rxinhed] #1067860 01/07/14 06:22 AM
Russell is correct. the light comes on every 75k miles. The switch is a little hard to see. The factory service manual shows the correct location. You really can't see it from above without a mirror. It slides sideways. After 150k miles you are supposed to pull the bulb anyway...
Hint: the only way I could understand you was from having grown up in Bama. It's an acquired skill.
Re: ERG valve ? [Re: fasteddy] #1067861 01/07/14 05:58 PM
Thanks Russell and Eddy....yep I made a mistake its 2.6 was just wondering if the light was coming on because I had put the weber on there and bypassed the system, I'll try and remove the bulb seems to be the way to go thanks for your help, sorry about the post writing to big of a hurry <img src="/forums/images/graemlins/shame.gif" alt="" />
PHP: 7.4.33 Page Time: 3.212s Queries: 15 (0.004s) Memory: 0.6028 MB (Peak: 0.6599 MB) Data Comp: Off Server Time: 2026-06-09 17:00:39 UTC
