Re: Need some advice on 95 SR no spark issue! [Re: fasteddy] #1068013 01/17/14 01:15 AM
tonygon Offline OP
Hey guys, so i bought the beast. Just now checking stuff... I was gonna start opening it up to check timing and cam and crank for physical damage. I noticed that there is no spark like i thought but there is no fuel either. Is there so ething off the top of anyones head that can cause both spark and fuel to be cut off? Coincidence? Thanks in advance, guys.
1988 MONTERO SWB 2.6L 5SPEEED MANUAL, 96SR LOCKED REAR, 8INCH FRONT LSD FRONT, AISIN MANUAL HUBS, CUSTOM F & R BUMPERS, ROCK SLIDERS, TUBE HALF DOORS, 9K WINCH, HOMEMADE SNORKLE, SOME OTHER STUFF.
Re: Need some advice on 95 SR no spark issue! [Re: tonygon] #1068014 01/17/14 04:39 AM
ryany Offline
Does it have an ECU & is it plugged in? <img src="/forums/images/graemlins/smile.gif" alt="" />
95 Montero SR
Re: Need some advice on 95 SR no spark issue! [Re: ryany] #1068015 01/17/14 05:18 AM
tonygon Offline OP
I think so. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Need some advice on 95 SR no spark issue! [Re: tonygon] #1068016 01/17/14 05:11 PM
ryany Offline
Well, that narrows it down a little bit. <img src="/forums/images/graemlins/smile.gif" alt="" />
I'd start with the basics - check all the fuses and fusible links, both under the dash and under the hood. Are the multiple wires at the positive battery terminal connected and clean?
Has the truck been messed with prior to you acquiring it, as far as anyone trying to diagnose it? That could open up all kinds of additional issues.
95 Montero SR
Re: Need some advice on 95 SR no spark issue! [Re: tonygon] #1068017 01/17/14 07:44 PM
P
pcc Offline
I noticed that there is no spark like i thought but there is no fuel either. Coincidence?
If no spark will the ECU allow fuel?
Re: Need some advice on 95 SR no spark issue! [Re: pcc] #1068018 01/18/14 02:20 AM
tonygon Offline OP
All fuses links and relays seem good. I checked for voltage signal at the tps connector since the ecm is supposed to send those 5 volts when turning the key to ignition and there is nothing.... So im guessing i'll check power supply and ground to the ecm, if both those are good, is it pretty safe to assume its the ecm? Thanks guys!
Re: Need some advice on 95 SR no spark issue! [Re: tonygon] #1068019 01/18/14 02:21 AM
tonygon Offline OP
By ecm i mean ecu, computer, etc.
Re: Need some advice on 95 SR no spark issue! [Re: tonygon] #1068020 01/18/14 06:11 AM
tonygon Offline OP
This is the patient: the $400 SR.
Re: Need some advice on 95 SR no spark issue! [Re: tonygon] #1068021 01/19/14 12:55 PM
That is a steal. Nice truck; hope you get everything resolved.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6349 MB (Peak: 0.7375 MB) Data Comp: Off Server Time: 2026-07-15 00:22:58 UTC
