Re: Need some advice on 95 SR no spark issue!
[Re: fasteddy]
#1068013
01/17/14 01:15 AM
Hey guys, so i bought the beast. Just now checking stuff... I was gonna start opening it up to check timing and cam and crank for physical damage. I noticed that there is no spark like i thought but there is no fuel either. Is there so ething off the top of anyones head that can cause both spark and fuel to be cut off? Coincidence? Thanks in advance, guys.
1988 MONTERO SWB 2.6L 5SPEEED MANUAL, 96SR LOCKED REAR, 8INCH FRONT LSD FRONT, AISIN MANUAL HUBS, CUSTOM F & R BUMPERS, ROCK SLIDERS, TUBE HALF DOORS, 9K WINCH, HOMEMADE SNORKLE, SOME OTHER STUFF.
[Re: tonygon]
#1068014
01/17/14 04:39 AM
Does it have an ECU & is it plugged in? <img src="/forums/images/graemlins/smile.gif" alt="" />
95 Montero SR 3.8 MIVEC, Advance headers, 2 1/2" exhaust, Magnaflow muffler, OME shocks & rear springs, 2" body lift, 3" tank lift, 4.90s, TRE front locker, factory rear locker, Roger Brown Rock Sliderz, 315/75r16 (35") tires, Sport big brakes
[Re: ryany]
#1068015
01/17/14 05:18 AM
Does it have an ECU & is it plugged in? <img src="/forums/images/graemlins/smile.gif" alt="" /> I think so. <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: tonygon]
#1068016
01/17/14 05:11 PM
Well, that narrows it down a little bit. <img src="/forums/images/graemlins/smile.gif" alt="" />
I'd start with the basics - check all the fuses and fusible links, both under the dash and under the hood. Are the multiple wires at the positive battery terminal connected and clean?
Has the truck been messed with prior to you acquiring it, as far as anyone trying to diagnose it? That could open up all kinds of additional issues.
[Re: tonygon]
#1068017
01/17/14 07:44 PM
I noticed that there is no spark like i thought but there is no fuel either. Coincidence? If no spark will the ECU allow fuel?
[Re: pcc]
#1068018
01/18/14 02:20 AM
All fuses links and relays seem good. I checked for voltage signal at the tps connector since the ecm is supposed to send those 5 volts when turning the key to ignition and there is nothing.... So im guessing i'll check power supply and ground to the ecm, if both those are good, is it pretty safe to assume its the ecm? Thanks guys!
[Re: tonygon]
#1068019
01/18/14 02:21 AM
By ecm i mean ecu, computer, etc.
[Re: tonygon]
#1068020
01/18/14 06:11 AM
This is the patient: the $400 SR. ![[Linked Image]](http://i125.photobucket.com/albums/p55/interpretes/2078b0cb8960638b7dd2d9b863652995.jpg)
[Re: tonygon]
#1068021
01/19/14 12:55 PM
This is the patient: the $400 SR. That is a steal. Nice truck; hope you get everything resolved. John B.
