Re: Tube bumper [Re: Malykaii] #1068537 02/03/14 09:50 PM
87monty Offline
Very cool I really like the front bumper, I wonder if you can make a pad for a winch?? I have one that needs to be installed.
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: Tube bumper [Re: 87monty] #1068538 02/04/14 12:41 AM
Yes you can. It's what i had to do since I had my front frame horns chopped and re-enforced. The Fabricator used thick plate to reinforce them and I could no longer fit a winch between the frame rails (otherwise that's where mine would have been mounted.
Anyway, you can see how I did my winch plate below...
Yeah it's a bit overbuilt but then again, I'd rather it be that than underbuilt especially since I don't have the facilities to do a full structural analysis of my design. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Tube bumper [Re: off-roader] #1068539 02/04/14 01:38 AM
87monty Offline
I like it! Very nice work <img src="/forums/images/graemlins/kewl.gif" alt="" />
96 SR
Re: Tube bumper [Re: 87monty] #1068540 02/04/14 02:09 AM
Thanks. Trying to do the whole KISS methodology on this design.
My friend Mike is a Navy certified welder (underwater, etc) and he welded it using an Arc welder we borrowed for the day from Carlos. This was built using a simple section of C-channel angle iron that was already the correct length which I then cut the corners off to fit in the space available. After welding it in place, we re-enforced with triangles of 1/4' plate I bought from OSH and cut into a square then triangles. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Tube bumper [Re: off-roader] #1068541 02/04/14 04:45 AM
87monty Offline
Did you build the bumper itself or is it a premade unit?
Im thinking of getting a hydro tube bender from harbor fright and making my own. I like this design you have.
96 SR
Re: Tube bumper [Re: 87monty] #1068542 02/04/14 05:33 AM
The bumper is a Smittybilt clone... Literally identical to the smittybilt.
Re: Tube bumper [Re: off-roader] #1068543 02/05/14 12:20 AM
87monty Offline
Is there a part# for this one that you know of?
I like how you renforced it also.
96 SR
Re: Tube bumper [Re: 87monty] #1068544 02/05/14 02:12 AM
We essentially chopped back the frame horns to the stock mounting holes and then plated them all around and back to the rest of the frame using cut to match 1/4-3/8" plate.
I don't know the smittybilt part number but IIRC, it's for the Jeep JK. You can easily tell though because their bumpers differ from model to model. The JK front mounts to a flat surface on the front of the rig rather than down the sides of the frame rails like our bumpers.
I'll have to doublecheck my rear bumper to see how it mounts up but IIRC it mounts on the sides of the frame rails unlike the front bumpers. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6370 MB (Peak: 0.7411 MB) Data Comp: Off Server Time: 2026-05-29 15:22:10 UTC
