Re: Better MPG any Ideas????? [Re: TainterRacing] #1068657 02/03/14 12:14 AM
geocrasher Offline
When I bought my raider it had 333K miles on it, got 10mpg. New-to-me Mikuni carb with secondaries working, 12mpg. New gas cap and a new vacuum hose going to the brake booster: 15mpg. Following a semi for over 100 miles at 55mph with all my belongings in the back :19mpg.
I once went from 17mpg around town to 21mpg around town in a ford taurus just by easing off the gas and driving more smoothly.
My suggestion to you: Put a valve spring under your accelerator :p
http://tidbitsfortechs.com/
Re: Better MPG any Ideas????? [Re: TainterRacing] #1068658 02/03/14 01:52 AM
Malykaii Offline
First off... l I'd ditch the Lucas. Oil viscosity effects mpg. Hence ford secs 5w20 in their 4.6 here but in and there's countries they call for 10w40. Lucas doesn't really do anything great. Want to maximize your mpg through oil... run a decent synthetic. Mobil 1 can be had on sale for 35$.
I wouldn't dare put that stuff in your diffs. Its not gl5 rated. It's not capable of handling the high shock of of direct contact gears. A lot of what lucas says isnt verified or true. See bobistheoilguy.com for the facts.
Maybe simple maintenance... change all your fluids and filters, a quick check of your alignment (tape measure will do), check air in tires, quick clean of the air flow meter is applicable, and check the drive line for resistance (wheel bearing play, drive shaft u joints...)
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
Re: Better MPG any Ideas????? [Re: geocrasher] #1068659 02/03/14 04:33 AM
1
1morebike Offline
with my land cruiser i had Scanguage and it really did help. it changes your driving style when you look down and see your currently getting 3 mpg because your trying to haul ass up hill. btw i hear you guys are getting killed with snow in Michigan, I'm heading that way tomorrow to go see my parents.
1990 5sp lwb 274,000 miles 80,000 on new motor
Re: Better MPG any Ideas????? [Re: 1morebike] #1068660 02/03/14 05:24 AM
TainterRacing Offline OP
well we have here about 38in on the ground the snow banks by my house are taller then the montero.
So Can the Lucas oil additive get some 5w-20 ??? can that run all right in the 3,0?
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: Better MPG any Ideas????? [Re: TainterRacing] #1068661 02/03/14 04:11 PM
ryany Offline
Make sure your maintenance is up to date - air filter, etc. Run the thinnest recommended oil and use synthetic - differentials also. Manual locking hubs will reduce the amount of drivetrain that you're turning while driving. Take any and all unnecessary weight out of the vehicle.
After all of that, adjusting your driving style is still the best way to get better mileage. If you're serious about wanting better mileage then lose the heavy foot and coast as much as possible.
95 Montero SR
Re: Better MPG any Ideas????? [Re: ryany] #1068662 02/03/14 09:01 PM
Malykaii Offline
I used the Ford motor as an example... not saying you should be using 0w20 or something. I'm not sure what your truck specs... 5w30? I'd stick with that, no lucas. If oil wasn't "stable" on its own, I believe companies like Mobile would have resolved that "issue" decades ago. I've only seen Lucas be of use in motors with blown rings. Even Blackstone Laboratories, one of the go to motor oil analysis labs, recommends not using it.
PHP: 7.4.33 Page Time: 0.181s Queries: 15 (0.007s) Memory: 0.6149 MB (Peak: 0.7011 MB) Data Comp: Off Server Time: 2026-10-31 21:02:44 UTC
