Page 2 of 4 1 2 3 4
Update: Re: 4crawler 2" BL on 94 SR [Re: JohnnyBfromPeoria] #1068697 02/22/14 04:33 PM
Djunk Offline OP
Got the Body lift installed. Overall it's a pretty straight forward job and doesn't take much time. A helper comes in pretty handy though. These are the details if anybody is interested.
- 94 SR Monty
- D12 kit with standard Hardware
- 12 2" Body mounts
Preparation:
-remove rear bumper
-remove fuel filler bracket (10MM bolt)
-remove a few bolts where the fuel lines cross from frame to body on the center underside of vehicle (maybe not necessary as I was able to reinstall these after the lift)
1. Remove the nuts on all twelve body mounts and took the bolts out on one side of the body.
2. Using a standard middle of the road floor jack and a 2 foot length of 2x4 jack up the body from the middle of one side of the body. There's a pretty good spot all along the bottom edge of the body to jack on.
3. lift the body high enough to place the 2" spacers. pretty much had to max out the the floor jack on the first side to accomplish this. Note: to remove the bolt from the front most body mount on each side you have to remove the rubber mounting pad first (two bolts on the bottom of the pad) then the bolt can be removed at an angle.
4. Place new bolts through the body mounts and spin the nuts on if possible hand tight.
5. Lower the body and repeat process on the other side.
6. Then go around and tighten all the BM down while a helper holds a wrench on the top side.
Note: As you lift the body make sure to massage the brake lines in the front through the holes in the wheel well.
Also do not interchange the old and new hardware they have a different pitch or something.
See above about Radiator mods.
94 SR Bought for $650. New Crank, Updated Lower Intake plenum, 15x8 procomp wheels driver side Bouncy Seat, Stock mitsu rear locker. Up coming mods; 35x12.5x15 Goodyear wrangler Kevlars, safari style roof rack, 2" BL, Spring spacers or OME springs, recovery gear.
Re: Update: Re: 4crawler 2" BL on 94 SR [Re: Djunk] #1068698 02/26/14 03:46 AM
W
willwinchforfood Offline
Pics or it didn't happen...
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: Update: Re: 4crawler 2" BL on 94 SR [Re: willwinchforfood] #1068699 02/26/14 03:07 PM
Djunk Offline OP
I was waiting for someone to bring that up. I'll try the next time I'm home but I won't be home till the end of next week. Till then it didn't happen....but did.
Re: Update: Re: 4crawler 2" BL on 94 SR [Re: Djunk] #1068700 02/27/14 03:01 AM
W
More lies! I cant decide between a one or two in lift. I'm making my own. I have the material just can't decide what to cut it down to. McMaster Carr sells 6ft rods of uhmp or whatever it's called for cheap
Re: Update: Re: 4crawler 2" BL on 94 SR [Re: willwinchforfood] #1068701 02/27/14 06:28 AM
Oso Offline
send 2 sets of 1" and i'll send you before and after pics to help make the decision - once i decide whether a 1" or 2" lift looks better. i'm always happy to help! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 4crawler 2" BL on 94 SR [Re: Canyonero] #1068702 02/28/14 03:10 PM
W
Does anyone have a photo of the area the T case shifter rubs? I am having trouble visualizing this.
Re: 4crawler 2" BL on 94 SR [Re: willwinchforfood] #1068703 02/28/14 03:18 PM
Djunk Offline OP
Can get the pics next weekend, though I think it's pretty staright forward once you see it. Just imagine that the the body was raised 2 inches but the the shifter did not move so now the shifter interferes a little with the plastic console. Easily taken care of by modifying the plastic console slightly.
Re: 4crawler 2" BL on 94 SR [Re: Djunk] #1068704 02/28/14 06:29 PM
ryany Offline
That seems to vary from vehicle to vehicle - I had no shifter issues when I installed the 2" BL on my 95 SR.
95 Montero SR
Re: 4crawler 2" BL on 94 SR [Re: ryany] #1068705 03/03/14 02:47 AM
MBrannon Offline
Can you post a link to where you bought the D12 kit?
Anyone have a picture of the general location of the 12 bolts?
thanks!
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: 4crawler 2" BL on 94 SR [Re: MBrannon] #1068706 03/04/14 12:02 AM
Djunk Offline OP
Here ya go http://www.4crawler.com/4x4/ForSale/MonteroBodyLift.shtml
On my SR there are 12 BM all together. 6 on each side. IIRC there is 1 up front, 3 along the side, and 2 in the rear. All easy to find/locate. for the two in the back just lift the carpet and pop the rubber caps off. Along the sides you have to remove the plastic trim holding the carpet down and the hard plastic lower portion behind the seatbelt. Far front are a little tought to get to throught the engine compartment but doable. May have to remove the air intake.
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6445 MB (Peak: 0.7530 MB) Data Comp: Off Server Time: 2026-06-10 01:49:03 UTC
