Page 3 of 4 1 2 3 4
Re: 4crawler 2" BL on 94 SR [Re: Djunk] #1068707 03/04/14 01:03 AM
Djunk Offline OP
Just re-found a posting over on Expedition Portal by eurosonic called "Eurosonic's Montero 2.5Gen Build Thread" post #10 begins a good write up on the BL and has tons of photos if anybody still wants something visual.
94 SR Bought for $650. New Crank, Updated Lower Intake plenum, 15x8 procomp wheels driver side Bouncy Seat, Stock mitsu rear locker. Up coming mods; 35x12.5x15 Goodyear wrangler Kevlars, safari style roof rack, 2" BL, Spring spacers or OME springs, recovery gear.
Re: 4crawler 2" BL on 94 SR [Re: Djunk] #1068708 03/05/14 04:23 AM
W
willwinchforfood Offline
I'm still of the opinion this entire thread is a farce until proven otherwise... I mean how do you know if I exist? Maybe I'm a SAL 9000.
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: Update: Re: 4crawler 2" BL on 94 SR [Re: willwinchforfood] #1068709 03/05/14 04:32 AM
Oso Offline
. I have the material just can't decide what to cut it down to. McMaster Carr sells 6ft rods of uhmp or whatever it's called for cheap
What diameter are you using?
Re: 4crawler 2" BL on 94 SR [Re: Djunk] #1068710 03/05/14 03:20 PM
Djunk Offline OP
Good point! I'm just going to assume that you don't exist.<img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" />
Re: 4crawler 2" BL on 94 SR [Re: MBrannon] #1068711 03/05/14 10:17 PM
Can you post a link to where you bought the D12 kit?
Anyone have a picture of the general location of the 12 bolts?
thanks!
The FSM will have a drawing of the locations.
Re: 4crawler 2" BL on 94 SR [Re: MontyMcV] #1068712 03/05/14 11:41 PM
PartyTruck Offline
LWB owners should add a boxtube of same size as BL ontop of the frame behind the rearwheels. There is a flatspot on the body that's supposed to mate to the frame when the rear is heavyly loaded. If you get sway in the body in the back the bodymounts will crack.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: 4crawler 2" BL on 94 SR [Re: PartyTruck] #1068713 03/06/14 12:30 AM
WOW! where have you been Partytruck? <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Update: Re: 4crawler 2" BL on 94 SR [Re: Oso] #1068714 03/06/14 12:41 AM
W
I think it's 2.5". I'll have to get it out again and measure. McMaster Carr sells the stuff in lengths of 8 ft I think but not center drilled. Easy enough to cut a little long and then face each end square and drill on a lathe. Any height lift you want, even 8 ft. Enough material to do several trucks.
Also I promise I'll post pics to assure you I live. I'll try to find one that includes my super hot wife. I'm still not sure if she exists or if someone just stole my bank account info and is stealing my money. Maybe I'm Partytruck. I'm all confused now.
Re: Update: Re: 4crawler 2" BL on 94 SR [Re: willwinchforfood] #1068715 03/06/14 01:07 AM
PartyTruck Offline
Yes you are and I have your wallet and that hottie here in Belize, plz take good care of my igloo and don't forget to hose the Ford down when it stops being dark for 11 months. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 4crawler 2" BL on 94 SR [Re: PartyTruck] #1068716 03/06/14 01:38 PM
Good point. The kit I got from Roger for my SWB came with square tube sections to bolt to the frame above the rear axle. I would assume he does the same for all his kits as needed. Of course, if you are making your own...
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6429 MB (Peak: 0.7511 MB) Data Comp: Off Server Time: 2026-06-09 21:45:27 UTC
