Page 2 of 4 1 2 3 4
Re: Need a gen1 front dif ASAP [Re: djacidjac] #1068743 02/05/14 09:36 PM
Monty Offline
I'm in the center of PA right along I80. About 30mins east of PSU.
The junk yard I took it to.
Martin Motor Company
(570) 726-4545 À 2512 Eagle Valley Rd, Mill Hall
1989 Raider V6/MT
2005 Jeep Liberty CRD Turbo Diesel
Re: Need a gen1 front dif ASAP [Re: Monty] #1068744 02/06/14 12:52 AM
Did you ever check car-part like I suggested? I just checked and I'm seeing them available from $50 and up in NY, $75 in PA for the front diff assy.
Re: Need a gen1 front dif ASAP [Re: off-roader] #1068745 02/06/14 04:55 AM
djacidjac Offline OP
Thanks everybody, looks like I can repair it tomorrow night.
I got it on a lift, pulled the dif cover and checked it all out. Gears and splines are all good. The snap ring on the inner shaft appears to be broken / missing, but it will require a few hours of work to replace. The snap rings under both hub covers were each ejected and laying inside intact. I replaced them with new snap rings. With all the snap rings off it was difficult to locate the trouble. I'm hoping that I don't find any deeper issues.
I found where that local parts truck was. Sadly, it is gone.
Thanks again!
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan
OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift).
5500lb winch, Starion alternator, grp31 marine bat'
OBA (stock AC compressor)
33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
Re: Need a gen1 front dif ASAP [Re: djacidjac] #1068746 02/07/14 05:58 AM
Still broken. Inner shaft splines stripped. Still need a front dif assembly. Preferably v6. No longer an emergency. But if i get 4x4 by Saturday, I'll make some loot and help a bunch of people.
Re: Need a gen1 front dif ASAP [Re: djacidjac] #1068747 02/07/14 08:08 AM
https://fbcdn-sphotos-b-a.akamaihd.net/h...283157585_o.jpg
Pic of the damage. I'm guessing the gear is messed up too. I didn't drop the dif, this peice slid out.
Has this happened to anybody? I haven't read about it.
Re: Need a gen1 front dif ASAP [Re: djacidjac] #1068748 02/07/14 03:45 PM
plh Offline
http://www.car-part.com
As I mentioned before - for the MT V6 swap you will need the CV shafts and front drive shaft too.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Need a gen1 front dif ASAP [Re: plh] #1068749 02/07/14 05:09 PM
Will a diff out of an automatic v6 not fit?
Re: Need a gen1 front dif ASAP [Re: off-roader] #1068750 02/07/14 05:28 PM
I'm not coming up with these parts / prices on car-part.com. I'm choosing "assembly, front axle...4wd" or something.
Re: Need a gen1 front dif ASAP [Re: djacidjac] #1068751 02/07/14 08:47 PM
plh Offline
Will fit* - not as strong as MT
* - not sure about the need of CVs and front drive shaft, should plan on getting these with the auto also - I'm just not sure on the auto cross match. I have the V6 MT version - so I know. (think I've said this before)
search "carrier" then make a phone call because this is a relatively generic term and may include the entire wheel to wheel assembly or as little as just the center bits. It takes some leg work.
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: Need a gen1 front dif ASAP [Re: plh] #1068752 02/08/14 02:02 AM
Has anyone verified a difference in the V6 housing, gears, etc. between the auto and stick vehicles?
I have observed a difference in the thickness of the CV bells on the stick truck, lucky Jason talked me out of the pair I had sitting. However, they'd not work with my plan for a Starion LSD in the V6 housing, like Dan (Mongo) has recently installed.
I have a loaded front 4-cyl housing I could send, but not in any hurry due to the present stormy weather.
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.005s) Memory: 0.6460 MB (Peak: 0.7508 MB) Data Comp: Off Server Time: 2026-06-22 14:15:32 UTC
