Re: Need a gen1 front dif ASAP
[Re: djacidjac]
#1068743
02/05/14 09:36 PM
I'm in the center of PA right along I80. About 30mins east of PSU.
The junk yard I took it to. Martin Motor Company
(570) 726-4545 À 2512 Eagle Valley Rd, Mill Hall
[Re: Monty]
#1068744
02/06/14 12:52 AM
Did you ever check car-part like I suggested? I just checked and I'm seeing them available from $50 and up in NY, $75 in PA for the front diff assy.
[Re: off-roader]
#1068745
02/06/14 04:55 AM
Thanks everybody, looks like I can repair it tomorrow night.
I got it on a lift, pulled the dif cover and checked it all out. Gears and splines are all good. The snap ring on the inner shaft appears to be broken / missing, but it will require a few hours of work to replace. The snap rings under both hub covers were each ejected and laying inside intact. I replaced them with new snap rings. With all the snap rings off it was difficult to locate the trouble. I'm hoping that I don't find any deeper issues.
I found where that local parts truck was. Sadly, it is gone.
Thanks again!
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift). 5500lb winch, Starion alternator, grp31 marine bat' OBA (stock AC compressor) 33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
[Re: djacidjac]
#1068746
02/07/14 05:58 AM
Still broken. Inner shaft splines stripped. Still need a front dif assembly. Preferably v6. No longer an emergency. But if i get 4x4 by Saturday, I'll make some loot and help a bunch of people.
[Re: djacidjac]
#1068747
02/07/14 08:08 AM
https://fbcdn-sphotos-b-a.akamaihd.net/h...283157585_o.jpgPic of the damage. I'm guessing the gear is messed up too. I didn't drop the dif, this peice slid out. Has this happened to anybody? I haven't read about it.
[Re: djacidjac]
#1068748
02/07/14 03:45 PM
http://www.car-part.comAs I mentioned before - for the MT V6 swap you will need the CV shafts and front drive shaft too.
- '83 Might Max: IG @83mmax
- '88 Raider: my OG
- '89 Raider: rescued
- '92 RS M/T: sold
- '93 SR: sent to crusher
- '05 Montero LTD: sold
- '18 PHEV: wife's daily
- '14 OL GT
- http://www.tuffpans.com
[Re: plh]
#1068749
02/07/14 05:09 PM
Will a diff out of an automatic v6 not fit?
[Re: off-roader]
#1068750
02/07/14 05:28 PM
I'm not coming up with these parts / prices on car-part.com. I'm choosing "assembly, front axle...4wd" or something.
[Re: djacidjac]
#1068751
02/07/14 08:47 PM
Will a diff out of an automatic v6 not fit? Will fit* - not as strong as MT * - not sure about the need of CVs and front drive shaft, should plan on getting these with the auto also - I'm just not sure on the auto cross match. I have the V6 MT version - so I know. (think I've said this before) I'm not coming up with these parts / prices on car-part.com. I'm choosing "assembly, front axle...4wd" or something. search "carrier" then make a phone call because this is a relatively generic term and may include the entire wheel to wheel assembly or as little as just the center bits. It takes some leg work.
- '88 Raider: my OG
- '92 RS M/T: sold
- '14 OL GT
[Re: plh]
#1068752
02/08/14 02:02 AM
Has anyone verified a difference in the V6 housing, gears, etc. between the auto and stick vehicles?
I have observed a difference in the thickness of the CV bells on the stick truck, lucky Jason talked me out of the pair I had sitting. However, they'd not work with my plan for a Starion LSD in the V6 housing, like Dan (Mongo) has recently installed.
I have a loaded front 4-cyl housing I could send, but not in any hurry due to the present stormy weather.
