Page 4 of 4 1 2 3 4
Re: Need a gen1 front dif ASAP [Re: rxinhed] #1068763 02/13/14 05:09 AM
I have a loaded front 4-cyl housing I could send, but not...
...you don't want a 4.625 gear ratio...
Re: Need a gen1 front dif ASAP [Re: djacidjac] #1068764 03/04/14 05:30 PM
djacidjac Offline OP
Just to wrap this up for anybody with the same trouble: I got the splines lined up by feel, pounded it back in with a hammer on a long screwdriver set against the middle of the inner shaft flange. I know it went all the way in because if it went any more the flange bolts would interfere.TIP: put the flange bolts in place before you pound the shaft back in. I did not replace the circlip. I have had no trouble with it since then. In the mean time, I ordered manual hubs because I could hear & feel the autos disengaging / half engaging. I think that contributed to the circlips and shaft getting ejected. I also took it easy; I found its limit! Should've tried this first, as suggested, but I was panicking and distracted.
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan
OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift).
5500lb winch, Starion alternator, grp31 marine bat'
OBA (stock AC compressor)
33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
Re: Need a gen1 front dif ASAP [Re: djacidjac] #1068765 03/05/14 12:12 AM
Oso Offline
congrats on getting it finished. i'd source the circlips while you wait for it to slip out. hope it doesn't happen but it's probably just a matter of time. at least you'll know how to get it done quickly and will have the parts on hand.
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6015 MB (Peak: 0.6722 MB) Data Comp: Off Server Time: 2026-06-23 18:44:13 UTC
