Re: 33's and auto trans... [Re: Mudraider] #1068779 02/05/14 11:30 PM
RECON45 Offline
I have not had any issues with rubing and 32's on the stock pomegranate wheels. I think though the 4dr runs a slightly wider axle than the 4cyl 2dr. I have a SR axle on m 2dr and no problem, but I could be wrong about the width. My 4dr with a 2in body lift has no issues either rubbing with 33" 12.5" tires.
Re: 33's and auto trans... [Re: RECON45] #1068780 02/06/14 12:53 AM
Schony Offline OP
You guy's are great thanks a lot! I have some serious thinking to do now lol decisions decisions <img src="/forums/images/graemlins/zombie.gif" alt="" />... If anyone has any other pic's of 32's on stock wheels it'd be much appreaciated. smile
Short List
Tires
Wheels (maybe)
Gen2 Upper Control arms
Gen2 rear coils
Gen2 brakes
Is there a differance in LS vs SR coils for the rear?
Re: 33's and auto trans... [Re: Schony] #1068781 02/06/14 02:03 AM
RECON45 Offline
Here is mine on the 32's and 3" lift
Re: 33's and auto trans... [Re: RECON45] #1068782 02/06/14 02:36 AM
Here are some links to this question that have been posted several times:
4x4 Wire Thread
4x4 Wire Thread
4x4 Wire Thread
4x4 Wire Thread
4x4 Wire Thread
Much information, like the above links, can be found using the search function in the toolbar. Use simple search words.
Re: 33's and auto trans... [Re: rxinhed] #1068783 02/06/14 05:09 AM
Ian Sharpe Offline
yeah brakes is the bigger issue IMO.
I changed to slotted rotors front & softer pads. Works very well. I also had new brake hoses made all round.
I also regeared to 4.90s (I have 99 model)
97 Exceed, 3.5l SOHC auto, 4.90 gears, ARB front locker,rear Harrop E-Locker, Magnum winch, dual transfer cases also 2008 NS swb Pajero, front bar & winch
Re: 33's and auto trans... [Re: Ian Sharpe] #1068784 02/06/14 05:57 AM
I'm not sure I agree with everyone regarding the brakes needing to be upgraded. On my gen 1 LWB v6 with 33's it stopped fine however, I wasn't driving it like it were a lightweight sedan. I drove it ensuring I had sufficient stopping distance between myself and others around me. With the stock setup, I could lock up all 4 without a problem which tells me there's sufficient braking power. In my experience, with the brake system in good condition and proper driving/braking technique which includes driving with a proper buffer between yourself and others around you, it did fine stopping.
Re: 33's and auto trans... [Re: off-roader] #1068785 02/06/14 06:02 AM
That's all fine and dandy til your on a 57 degree slope. I love my big brakes and swear by them as opposed to swearing at my adjusted Gen 1 brakes. Personal observation based on having run both.
Re: 33's and auto trans... [Re: Mudraider] #1068786 02/08/14 02:19 AM
V6 brakes, at a minimum, if you want to stop on a 57 degree slope. With the 4-cyl brakes, my water tank trailer (with 200 gallons of water) outmatched my Raider once, causing me to swear rolling through a 4-way stop intersection. Wasn't my turn, everyone stayed put with my horns blaring and lights on hi beams. Not even much compression braking under that load!
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.005s) Memory: 0.6322 MB (Peak: 0.7330 MB) Data Comp: Off Server Time: 2026-07-09 21:13:56 UTC
