Re: 2.4 Conversions
[Re: cjsmontero]
#1068969
02/12/14 02:38 PM
You need a "wide block" 2.4L; one that came from a rear-wheel drive vehicle. Most front wheel drive variants of the 4g64 are narrow block and won't mate up to the transmissions of the Montero without an adapter. The wide block mounts to the same transmissions as the V6.
Let's not forget about the elusive twin-cam 2.4L. Only 1 year in the Galant (narrow block) but 160HP and 160lbs/ft. I do not know if the 2.3 DOHC head on the 2.4 block gives the same NA power, as most turbo these when making the conversion.
94 LS 3.0
Re: 2.4 Conversions
[Re: Lesharoturbo]
#1068970
02/12/14 05:51 PM
i have a build-able 2.4 short wide block
Re: 2.4 Conversions
[Re: mxmikie]
#1068971
02/12/14 07:10 PM
Most all the heads swap among the 4g63 and 4g64, so making one a dohc 16v is no trouble. The trouble arises with the water outlet, which is on the rear of the head, and you have to get creative.
I repeat, all this is covered in projectzerog.com, mostly pioneered by the starquest crowd. There are low profile outlets with remote tstats and a way to remove a freeze plug in the front of the head and install a tube there.
I thought the 2.4 wide block fit the 2.6 bellhousing pattern - pretty sure as a matter of fact. You can still use the km148 from a v6 with the I4 bellhousing, but you are still stuck with the km145 m/t, unless somebody has come up with a 2.6 bellhousing that will fit on the v6 heftier 5spd. I think the tranny came behind one of the diesels, so that's a possibility.
Re: 2.4 Conversions
[Re: fasteddy]
#1068972
02/13/14 12:16 AM
There was a thread in the last year on a V5MT and 2.6 with an export market diesel bellhousing. Seemed like the talk was it can work, but don't recall anyone saying they did it. Someone in the US nabbed a bellhousing. I want to say it was PLH...?
Re: 2.4 Conversions
[Re: MontyMcV]
#1068973
02/13/14 12:44 AM
The water outlet on the rear might not be a issue if you have a v6 trany with the 2.6 bell. It sets forward about 2in more then the 2.6 trany.
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: 2.4 Conversions
[Re: TainterRacing]
#1068974
02/13/14 12:57 AM
My 2.4, from a '90 Mighty Max, bolted up to my KM-148 auto with no mods.
Re: 2.4 Conversions
[Re: fasteddy]
#1068975
02/13/14 02:21 AM
but you are still stuck with the km145 m/t, unless somebody has come up with a 2.6 bellhousing that will fit on the v6 heftier 5spd. I think the tranny came behind one of the diesels, so that's a possibility. Yes I do have a bellhousing and TOB fork that mates the 4cyl to the v6 (v5mt1) manual transmission. It did come in the diesel (4D56t) Gen 2. Bought it in Thailand. Carried it back in my luggage last summer.
- '83 Might Max: IG @83mmax
- '88 Raider: my OG
- '89 Raider: rescued
- '92 RS M/T: sold
- '93 SR: sent to crusher
- '05 Montero LTD: sold
- '18 PHEV: wife's daily
- '14 OL GT
- http://www.tuffpans.com
Re: 2.4 Conversions
[Re: plh]
#1068976
02/13/14 04:37 PM
When's your next trip? I'll send you an extra suitcase and some money, seriously. A V5MT1 with Active-Trac behind a turboed 2.6... <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 2.4 Conversions
[Re: MontyMcV]
#1068977
02/13/14 07:59 PM
When's your next trip? I'll send you an extra suitcase and some money, seriously. A V5MT1 with Active-Trac behind a turboed 2.6... <img src="/forums/images/graemlins/smile.gif" alt="" /> Late April or early May 2014 as it stands now. We can talk...
- '88 Raider: my OG
- '92 RS M/T: sold
- '14 OL GT
Re: 2.4 Conversions
[Re: plh]
#1068978
02/14/14 01:25 AM
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
