Re: New front bumper build. Need some help
[Re: Oso]
#1069193
02/15/14 07:10 PM
Here's the first revision. I added High Lift jacking points and have gussets on them for strength. Let me know if you guys have any more ideas. I'm going to be cleaning the design up this week and hopefully be burning it out next weekend. Also, the holes for the lights are for 3" round lights. I might make them bigger, I haven't decided yet. ![[Linked Image]](http://www.supermotors.net/getfile/1011463/fullsize/bumper-final-assy1.jpg)
1990 LWB 3.0 Auto Tan interior Mostly Stock 194k
[Re: Devilmontero]
#1069194
02/16/14 01:40 AM
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
[Re: Devilmontero]
#1069195
06/08/14 03:12 AM
![[Linked Image]](http://www.supermotors.net/getfile/1025811/fullsize/monetero-010.jpg) ![[Linked Image]](http://www.supermotors.net/getfile/1025813/fullsize/monetero-012.jpg) I know it's been awhile since I posted an update but here's the bumper brackets installed for the new bumper. Now I just have to get the bumper laser cut. If anyone wants any drawings or part files, just PM me. Hopefully I will have some bumper pics in the next couple weeks.
[Re: justice]
#1069196
06/08/14 07:30 PM
Fully agree with Justice on exterior mounting of Hi-lift, but for another reason. Have seen some jeepers with exterior mounted ones go to use them and the spring breaks, even with the cover on them. When you say gusset the hi-lift hole, is that just a square with a matching hole welded inside to make that thicker?
[Re: Mudraider]
#1069197
06/09/14 02:57 AM
The high lift jacking point is at the bottom of the bumper where the two holes are. I bent in that tab then reinforced it with two triangle gussets on both sides. As soon as I get to my computer I will post a picture.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6117 MB (Peak: 0.6767 MB) Data Comp: Off Server Time: 2026-05-30 03:46:48 UTCValid HTML 5 and Valid CSS
