Backspacing for 35's #1069573 02/26/14 02:47 PM
F
Fujisawa_Rob Offline OP
2000 Montero, will have 2" BL before larger tires.
Looking at 35" BFG KM2s, 12.5" wide, on 15x8 rims.
Is 3.5" okay for backspacing?
I apologize if this is a common question, I thought I'd read it somewhere but can't find it now.
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: Backspacing for 35's [Re: Fujisawa_Rob] #1069574 02/26/14 04:09 PM
That's what i run and i have no rubbing and no suspension lift anymore. 35x13.5 on 15x10" wheels 3.5 BS
Re: Backspacing for 35's [Re: TOASTY] #1069575 02/26/14 10:49 PM
I run 35x12.5/15 on 8" wheels with 3.5 - 3.75" BS with no problems.
I also run my 86 with 33x12.5-15 on the stock 7" SR wheels with virtually no problems. It will rub when leaving a downward facing driveway with the wheels cranked all the way to the right, but that's not the fault of the backspacing.
Re: Backspacing for 35's [Re: JohnnyBfromPeoria] #1069576 02/26/14 10:54 PM
F
Hmm...does the 86 get much highway time? I'd be a little concerned about a 12.5" wide tire on a 7" rim. I think they'd be fine off-road.
Re: Backspacing for 35's [Re: Fujisawa_Rob] #1069577 02/27/14 03:40 AM
[quote]Hmm...does the 86 get much highway time? I'd be a little concerned about a 12.5" wide tire on a 7" rim.
It's fine.
I used to run Toyo Open Country M/T's in 33x12.5/15 on the stock 7"W wheels (95 SR) and they wore evenly and the truck handled well with that set-up.
Re: Backspacing for 35's [Re: JohnnyBfromPeoria] #1069578 02/27/14 03:44 AM
F
I'm not having much luck finding wheels with a 108mm center opening, at least used.
New, there's the Black Rock 15x8, 4.25" center bore. Offset is listed as 4", but I don't know the backspacing.
Re: Backspacing for 35's [Re: Fujisawa_Rob] #1069579 03/03/14 03:00 AM
MBrannon Offline
I'd still like to run 35x12.5 on the stock rims. I really just like the look of the stock rim and of course hate to spend money on new ones if i don't have to.
Anyone run a 35x12.5 on a stock 7" rim?
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: Backspacing for 35's [Re: MBrannon] #1069580 03/03/14 05:21 AM
Even better, my next-door neighbor caught the 1st Gen bug years ago and a shop actually mounted 33x12.5/15's on the stock 6" wheels. That's about as tight as I've seen.
It would work, but I'd be very careful to set air pressure with a "chalk check," for proper tread pattern spread. You might end up at some crazy low pressure to get the set-up right, but keep in mind the tires are rated to carry a lot more weight at max pressure than you need them to do, so a lower cold pressure may be the only way to get them to form a good contact patch.
Re: Backspacing for 35's [Re: Fujisawa_Rob] #1069581 03/05/14 07:31 PM
F
Any reason these wouldn't work?
Black Rock 909s
Re: Backspacing for 35's [Re: Fujisawa_Rob] #1069582 03/05/14 07:42 PM
What's the center bore? Needs to be at least 108mm... which is really max for a 6x5.5" bolt pattern rim.
Otherwise I think they will work. Always test fit them first though if at all possible. That's what I did at America's tire when buying my rims.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6386 MB (Peak: 0.7641 MB) Data Comp: Off Server Time: 2026-06-09 00:34:06 UTC
