Backspacing for 35's
#1069573
02/26/14 02:47 PM
2000 Montero, will have 2" BL before larger tires.
Looking at 35" BFG KM2s, 12.5" wide, on 15x8 rims.
Is 3.5" okay for backspacing?
I apologize if this is a common question, I thought I'd read it somewhere but can't find it now.
Re: Backspacing for 35's
[Re: Fujisawa_Rob]
#1069574
02/26/14 04:09 PM
That's what i run and i have no rubbing and no suspension lift anymore. 35x13.5 on 15x10" wheels 3.5 BS
[Re: TOASTY]
#1069575
02/26/14 10:49 PM
I run 35x12.5/15 on 8" wheels with 3.5 - 3.75" BS with no problems.
I also run my 86 with 33x12.5-15 on the stock 7" SR wheels with virtually no problems. It will rub when leaving a downward facing driveway with the wheels cranked all the way to the right, but that's not the fault of the backspacing.
[Re: JohnnyBfromPeoria]
#1069576
02/26/14 10:54 PM
John B. Hmm...does the 86 get much highway time? I'd be a little concerned about a 12.5" wide tire on a 7" rim. I think they'd be fine off-road.
[Re: Fujisawa_Rob]
#1069577
02/27/14 03:40 AM
[quote]Hmm...does the 86 get much highway time? I'd be a little concerned about a 12.5" wide tire on a 7" rim. It's fine. I used to run Toyo Open Country M/T's in 33x12.5/15 on the stock 7"W wheels (95 SR) and they wore evenly and the truck handled well with that set-up. John B.
#1069578
02/27/14 03:44 AM
I'm not having much luck finding wheels with a 108mm center opening, at least used.
New, there's the Black Rock 15x8, 4.25" center bore. Offset is listed as 4", but I don't know the backspacing.
[Re: Fujisawa_Rob]
#1069579
03/03/14 03:00 AM
I'd still like to run 35x12.5 on the stock rims. I really just like the look of the stock rim and of course hate to spend money on new ones if i don't have to.
Anyone run a 35x12.5 on a stock 7" rim?
1992 VR4 12.5 @ 110 - SOLD 1993 Stealth RT/TT 11.4 @ 129 - SOLD 1991 VR4 9.2 @ 159 - Old Shop Car 1992 Stealth Twin Turbo ATX - SOLD 1990 Montero LS LWB - RIP 1995 Montero LS - RIP 1998 Montero 1992 Galant VR4 474/1000 2007 Prius
[Re: MBrannon]
#1069580
03/03/14 05:21 AM
Anyone run a 35x12.5 on a stock 7" rim? Even better, my next-door neighbor caught the 1st Gen bug years ago and a shop actually mounted 33x12.5/15's on the stock 6" wheels. That's about as tight as I've seen. It would work, but I'd be very careful to set air pressure with a "chalk check," for proper tread pattern spread. You might end up at some crazy low pressure to get the set-up right, but keep in mind the tires are rated to carry a lot more weight at max pressure than you need them to do, so a lower cold pressure may be the only way to get them to form a good contact patch. John B.
[Re: Fujisawa_Rob]
#1069582
03/05/14 07:42 PM
What's the center bore? Needs to be at least 108mm... which is really max for a 6x5.5" bolt pattern rim.
Otherwise I think they will work. Always test fit them first though if at all possible. That's what I did at America's tire when buying my rims.
