Re: Starion Diff on ebay [Re: Malykaii] #1070463 04/03/14 02:58 AM
Malykaii Offline
Now I have a question?
Say I want to regear. I can do 4.9 m/s with gen2 rear...but
What about the front? I know 4.875 exists but is that a gen1 2.6 gear, gen1 v6 gear, or available in both? And most importantly, how does that factor into the lsd swap.
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
Re: Starion Diff on ebay [Re: Malykaii] #1070464 04/03/14 03:12 AM
TainterRacing Offline
I not sure about the 83 I know they are not the same I believe it matters on if it was a early on 83. some 83's have the 82 stuff that was not sold here any how I don't think many would be able to find one any how.... I was young and dumb and trashed the one I had........
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: Starion Diff on ebay [Re: TainterRacing] #1070465 04/03/14 04:36 AM
Oso Offline
The 87 was a transitional year. I used an early 87 and had lots of fun. The d/s v6 cv was 25 splines and slid right in. The p/s c/v has 28 splines and wouldn't work. A 4 cyl jack shaft was the solution. Its identical - just a hair smaller in diameter. The 4cyl & v6 used the same c/v on the p/s so both will bolt up to up to the jack shaft.
If you end up going with the 4 cyl jack shaft remember to change the seals on the new shaft and diff as well or you'll leak oil. Another member found this out the hard way and was kind enough to clue me in before I buttoned everything up.
It's also a great reason to install manual hubs otherwise slippery road conditions can bring some excitement when 4wd is engaged.
Not sure about the gearing. I know that my front lsd is 4.625 and the SR rear is 4.636.
Fwiw - there are two starion lsds already on the parts board here. Tonygon's is complete with a v6 housing. And yeah, the other one is mine...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6000 MB (Peak: 0.6540 MB) Data Comp: Off Server Time: 2026-05-29 21:08:11 UTC
