replacing outer boot on left front drive shaft - HOW? #1070524 04/03/14 09:42 AM
BAZINGA Offline OP
Hi all,
I've just disassembled my front left wheel to replace the outer boot on the drive shift.
After removing the knuckle and the old boot, for the life of me I can't see how to disassemble the cv joint to slide on the new boot.
I'm hoping I don't have to do it from the inside!
How do I do it?
99 Auto Sportage. Wildcat Extractors, Lukey Turbo Muffler, Warn manual hubs, K&N Air filter, Tyres 30/9.5/15, Ironman 40mm springs, KYB front struts & rear shocks, GME TX3220 UHF radio, dual battery system. Twin 10" electric fans. Next Job: Body lift
Re: replacing outer boot on left front drive shaft - HOW? [Re: BAZINGA] #1070525 04/04/14 08:11 AM
BAZINGA Offline OP
Well, after a restless night I got up this morning with a clearer head. According to kiatechinfo.com you can't disassemble the cv joint on the wheel side.
YouTube to the rescue.
All I had to do was tap the back of the cv joint with a hammer and of it came off.
Then slip on the boot, tighten the strap.
Fill the cv joint with the grease in the kit. Work the grease in by moving the cv around.
Put the cv back on the drive shaft and tap it back on with a hammer.
There you go.
Overall it wasn't too hard.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5866 MB (Peak: 0.6342 MB) Data Comp: Off Server Time: 2026-10-24 20:13:50 UTC
