Re: Evoscan?? [Re: TOASTY] #1070647 04/08/14 05:17 AM
rskvjk Offline OP
rofl- I wouldn't even trust this truck to make it to the closest dealer right now- which is 2 hrs away.
95 Montero 3.0 24v Newly Rebuilt; Automatic- work in progress
Re: Evoscan?? [Re: rskvjk] #1070648 04/11/14 10:00 PM
A
azazel Offline
I have Evoscan for my 2004 Evo 8 RS. It does not work with the Montero. My ELM137 Bluetooth OBDII device may work. I will give it a try. If it does you can Bluetooth your phone to the device and run gauges for any of the sensors you care to monitor.
http://www.newegg.com/Product/Product.aspx?Item=9SIA1M80MK2501
I let a friend borrow the device so I will have to wait till later next week to test it.
On my Galant VR4 I use http://www.technomotive.com/prod/datalog/datalogger.htm
The no longer make it but it could work for Pre OBDII Montero's.....I just don't have one to try it on.
1994+1995 Montero SR
2003 Montero Limited
1990 Mighty Max 6G72 4x4
2014 Outlander Sport (Wife)
1992 Galant VR4 (724)
2004 Mitsubishi Lancer Evo RS - (SOLD)
+ Other Non Mitsu's
Re: Evoscan?? [Re: azazel] #1070649 04/20/14 02:37 PM
A
azazel Offline
The ELM137 tool didn't work. I don't think it has the right protocol to talk to the ECU....
+ Other Non Mitsu's
Re: Evoscan?? [Re: TOASTY] #1070650 04/20/14 06:06 PM
BottomFeeder Offline
Move to Az and i'll let you use my MUT-II, today i used it to set my new TPS. Man that was easy.
After looking at This Item I am thinking it might be cheaper to move to AZ?
1990 Montero LS "Bottom Feeder" LWB, 33's, Cheapass Lift, 2" body lift, Dual BoUnCyS, Dual LSD's, KC's.
1995 Montero SR Complete LS interior swap and a BoUnCy from a 96 SR. General Grabber AT2's 33X12.5. 1.5" Body Lift
Re: Evoscan?? [Re: BottomFeeder] #1070651 04/21/14 07:23 PM
And that one would need the rom pack for cars still.
Re: Evoscan?? [Re: TOASTY] #1070652 04/27/14 03:35 AM
PHIL_ Offline
Just for future ref, evoscan does work on the gen3, 2003+ 3.8s. I threw a DTC on the way to Red Deer today. Evoscan said it was a P0456 (evap emissions small leak). Probably didn't tighten the gas cap enough. Lol. But it does pick up the 3.8 in case anyone is wondering. You can scan through obd or MUT2 protocols. Also works for abs codes too.. It couldn't do a damn thing with my diesel though. Heheh...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6167 MB (Peak: 0.6871 MB) Data Comp: Off Server Time: 2026-06-13 10:55:44 UTC
