Page 3 of 3 1 2 3
Re: My 99 lost coolant, blew something...Oh No! [Re: justice] #1070687 05/05/14 07:05 AM
justice Offline OP
Got heads on and torqued down, Crossover pipe bolted on (PITA) and exhaust manifolds all bolted up..Soon
Re: My 99 lost coolant, blew something...Oh No! [Re: justice] #1070688 05/05/14 06:32 PM
Jay Ayala Offline
He'll yeah justice. When your done have your daughter drive it again and get her impressions on how it performs. I bet she will be stunned at the difference.
Re: My 99 lost coolant, blew something...Oh No! [Re: Jay Ayala] #1070689 05/05/14 10:59 PM
justice Offline OP
Yea it should be interesting to see if there is a marked difference in power. It was amazing how much carbonized oil deposits were in the lower intake and intake ports of the heads..about 1/8" of buildup.
I am thinking of installing a catch can to catch oil between the EGR and the intake to remove it before it get back in. still researching that a bit.
Re: My 99 lost coolant, blew something...Oh No! [Re: justice] #1070690 05/07/14 02:11 AM
justice Offline OP
Cleaned up upper intake and cleaned out EGR ports.
noticed heavy casing marks on the edges of the runners, decided to smooth those over a bit.
Still a little smoothing out to do.
Re: My 99 lost coolant, blew something...Oh No! [Re: justice] #1070691 05/08/14 03:28 PM
justice Offline OP
Been working to much to get much progress done this week. Installed the timing belt and put the valve covers on Got some other parts cleaned up and ready to put on though, Cleaned the big accessory bracket yestersay. Should not be long now. Should have it up and going this weekend if everything goes well.
Re: My 99 lost coolant, blew something...Oh No! [Re: justice] #1070692 05/11/14 05:19 AM
justice Offline OP
Here's my version of the mitsu special tool...
I used a drill bit for the "pin" this pic is after the tension was set and then checking after rotating crank 360 degrees.
This is where I ended tonight, almost there. Need to bolt the battery tray back in,install batt, put air cleaner and pipe on and tighten the exhaust flanges....hope it starts.
<img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: My 99 lost coolant, blew something...Oh No! [Re: justice] #1070693 05/11/14 05:30 AM
justice Offline OP
Forgot to add that I took the alternator in to the clowns at autozone to get tested due to an intermittent light on the dash going on then tuning off after a while..replaced a dead battery not too long ago so it was suspect. It failed, of course autozone wanted to sell me one of their lifetime remans for over 200 bucks. No thanks. Some of you may remember how many of those I went through on my 89.
I found Amazon had these OEM Brand Denso's (re-manufactured by Denso with Denso internals for $128. Not bad considering this is a 100 Amp Alternator.
Re: My 99 lost coolant, blew something...Oh No! [Re: justice] #1070694 06/18/14 11:20 PM
Jay Ayala Offline
Jay should be the same SOHC 3.5 but I cant garantee it. My castings were G7S4FR.
Hi Justice, I was able to pull the engine on my 1997 over the past few days. Actually, I helped my wife pull the engine. I found that we have the same cast number for the cylinder heads. Thought you should know. Justice, did I miss an update on your rig? How is it working?
Re: My 99 lost coolant, blew something...Oh No! [Re: Jay Ayala] #1070695 06/19/14 07:35 AM
justice Offline OP
It runs great. Idles smooth plenty of power, But it has a noise that I believe is coming from the bottom end. I'm thinking a bearing gave way down there due to the over heat. Win some loose some I guess. I'm thinking I'll look for a good used 3.5 or 3.8 and swap the new heads over then swap it in. Daughter drives it to work and it does fine though I'm not comfortable towing my boat with it the way it is. Picked up a Gen 3 the other day so that will be handling the towing duties.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6424 MB (Peak: 0.7479 MB) Data Comp: Off Server Time: 2026-06-17 10:43:33 UTC
