Page 2 of 3 1 2 3
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: roninguitars] #1071159 04/29/14 02:31 AM
PHIL_ Offline
Wow that's a lot of money. I'm going to be putting my 93 second gen with 2.8 diesel up for sale next month (the whole truck) for $6500 Canadian, so you can imagine it sounds high to me for just the engine.... If you want new, then obviously that's the way to go, but I regularly see whole/running diesel Pajeros on Canadian sites for about what you're being quoted for just the engine. Even if you just buy one for parts, at least you have everything you need, diffs, trans, etc. Maybe you've looked at this already and simply want a new engine? That's cool too.
As far as diff ratios, my 4D56 came with 488s and I feel that with any shallower it would've been under geared. I ran 33s on it, but still... My current Pajero with the 2800 diesel has 490s, and again, I wouldn't have wanted any (numerically) lower than that.
I'd definitely recommend an intercooler whichever way you go, and an EGT gauge. These little diesels will pull all day, but to their destruction if you don't manage the heat.
Not sure if any of this is helpful and you know what opinions are like, but enjoy your project!
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: PHIL_] #1071160 04/29/14 05:10 AM
Similar thread about gears
The Gen I V6 Montero uses a 9" ring gear in the rear, an 8" in the front.
The 4-cyl Monteros are confirmed to have 4.22, 4.625 (most common), and 4.875 gears.
The 4-cyl Montero/Raider and Mighty Max/D50 had the smaller diffs: 7.5" front, 8" rear...until at least '89 when the 2.6L was discontinued, I've no idea about the 2.4L-era MM.
The 3.909 are most common in 4-cyl MM. Spence is also looking for the 3.54 ratio 7.5" ring gear for his new truck, so you'll have competition.
Russell
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: rxinhed] #1071161 04/29/14 06:33 PM
Instead of higher gears why not just go taller tires?
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: lordtrunks] #1071162 04/30/14 01:39 AM
plh Offline
I think for the price of a new 4d56 that Spence posted that is the way to go
Hindsight, me too.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: plh] #1071163 04/30/14 04:40 AM
Hindsight, me too.
Me too except I figured out my oil leak so now i'm not so sure <img src="/forums/images/graemlins/lol.gif" alt="" /> turns out the guy who did the post break in lash adjust forgot to tighten the valve cover down.
*it was me <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: TOASTY] #1071164 04/30/14 06:43 PM
plh Offline
Hindsight, me too.
Well then he should just buy yours! its a heck of a good deal. Just not right for me at the moment. Wife has me looking at an RV (diesel).
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: roninguitars] #1071165 05/09/14 09:34 PM
JeffatTireBalls Offline
I bought a new 4d56 from Maximumoverdrive 3 years ago, it's been great! Here is my build thread http://www.4x4wire.com/forums/showflat.p...&PHPSESSID=
99 Montero SR
Mazda B2600i with 4D56T diesel swap http://www.4x4wire.com/forums/showflat.p...ID=#Post1240274
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: roninguitars] #1071166 05/13/14 12:26 AM
red1987raider Offline
Hi, John. Just caught your post. I put a 4D56T in my '87 Dodge Raider. I posted the process on this site, so here's the link:
I bought the engine on eBay for about $1600. It was a long block, but had no accessories. I had to scrounge around for pulleys, starter, power steering pump, fan, etc. Finally got it all together and the truck runs well. Read what I posted and let me know if I can help. I have contacts for a lot of stuff. All the best, Bob in Maine
1987 Dodge Raider converted to 4D56T
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: red1987raider] #1071167 06/29/14 08:38 PM
roninguitars Offline OP
Looks like I am going with a complete engine including wiring harness from a mid 90's Delica with 98k on the motor. It doesn't come with an intercooler but I know that is something that can be done afterward. I will post some photos when it all arrives. The price is about half of the new engine.
I will stick with the stock 4.66 diff and see how she drives. Getting the best MPG possible is a high priority so I will begin tweaking it out once she is up and running.
I've got a lead on a gauge cluster from an 89 Shogun MK1 diesel. If anyone has experience with using this to solve the tach problem let me know.
"I'm gonna whittle you into kindling' Black Crow 16 shells from a thirty-ought-six" - Tom Waits
Re: New Member 86 Montero SWB MT - 4d56 Swap Project [Re: roninguitars] #1071168 06/30/14 07:26 PM
LandRaider Offline
I put a diesel tach into my diesel swapped truck. I just used the old wire that was on the - side of the coil, and wired it to the hall effect switch on the IP. Works great.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6494 MB (Peak: 0.7567 MB) Data Comp: Off Server Time: 2026-06-10 07:18:33 UTC
