95Sr still has Miss under load???
#1071529
05/05/14 10:35 PM
Not sure what is causing this. Any ideas? I sealed the the IAC and Thermostat in the Throttle body and just had alternator rebuilt. I have switched <img src="/forums/images/graemlins/confused.gif" alt="" /> around the coil paks. The only thing I haven't done is replace the spark wires.
Re: 95Sr still has Miss under load???
[Re: sasnydley]
#1071530
05/06/14 12:36 AM
If it's the power transistor assy, two cylinders will be missing. You have waste spark. Three coils fire six plugs. Three pt's fire one coil each. I'd look at the wires and the plugs.
[Re: fasteddy]
#1071531
05/06/14 12:35 PM
check the injector connectors
[Re: mxmikie]
#1071532
05/06/14 02:53 PM
Seems if a coil is bad, moving it wouldn't solve your problem, it would just relocate it to different cylinders, no?
What kind of plugs you got in there? Hopefully NGK. I've had brand new Bosch and Champion plugs miss under load before in other vehicles.
98 Montero, 184k.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6019 MB (Peak: 0.6574 MB) Data Comp: Off Server Time: 2026-05-29 14:35:09 UTCValid HTML 5 and Valid CSS
