How to Tell which cam is Exhaust and which is Intake? #1071850 05/21/14 02:48 PM
A
azazel Offline OP
95 Montero SR 3.5 DOHC
I am thinking my non starting issue is due to swapping the intake and exhaust cams or having two exhaust cams...etc.
How and I tell which cam is which? Right now the head is in the truck but I plan to pull the plenum and pop the valve cover. From there I can change out cams....
Are there marks I can look for? Any ideas?
1994+1995 Montero SR
2003 Montero Limited
1990 Mighty Max 6G72 4x4
2014 Outlander Sport (Wife)
1992 Galant VR4 (724)
2004 Mitsubishi Lancer Evo RS - (SOLD)
+ Other Non Mitsu's
Re: How to Tell which cam is Exhaust and which is Intake? [Re: azazel] #1071851 05/21/14 04:48 PM
PA_JERO, CAP510 and Canyonero have all had this problem due to the machine shop mixing the cams up. Try contacting PA_JERO he's got engines laying around to look at.
Re: How to Tell which cam is Exhaust and which is Intake? [Re: azazel] #1071852 05/21/14 05:03 PM
JoeBurt Offline
I found a couple of pics that might help:
http://engineguy.com/1996-94-mitsubishi-3-5-l-engine-6g74-atk251-vin-m.html
I'm not too sure if the following link are the same as the 6g74 Montero cams:
http://www.3sx.com/faq/cams/index.asp
Re: How to Tell which cam is Exhaust and which is Intake? [Re: JoeBurt] #1071853 05/21/14 05:24 PM
A
azazel Offline OP
Here is my theory...hope its right.
On the passenger side bank, the manual says you need to hold the cam sprockets when installing the T-belt. Yet, I didn't need to do this. Considering that I have spark, fuel and timing correct I am thinking I reversed the cams.
I looked at the pics...I am going to compare them to my spare set of Cam's and see if I can find the smoking gun.
+ Other Non Mitsu's
Re: How to Tell which cam is Exhaust and which is Intake? [Re: azazel] #1071854 05/21/14 05:33 PM
JoeBurt Offline
Yeah, the drivers side cams will sit at the correct timing position but the passenger side I had to get 2 wrenches to hold them while I put the timing belt on. They should be under spring tension from the valves.
I would definitely double check the timing before you rip everything apart just in case.
PHP: 7.4.33 Page Time: 1.094s Queries: 15 (0.004s) Memory: 0.6063 MB (Peak: 0.6711 MB) Data Comp: Off Server Time: 2026-06-06 15:28:26 UTC
