Complete Montero SR Airlocker rear axle FOR SALE #1072741 07/01/14 08:31 PM
G
Gravesdigger Offline OP
I have a complete rear axle from a 96 or 98 Mitsubishi Montero SR. It is airlocker axle 9.5" ring gear and has 4.63:1 gears. (51 ring, 11 pinion).
The only thing missing is one set of brake pads and a couple nuts.
Located in SLC, Utah
asking $200 or best offer.
I can ship on your dime and I accept PayPal, Cash, or Money Order (provided it clears the bank).
This is a great upgrade for your Montero and the third will bolt into most of them.
offroading is fun
Re: Complete Montero SR Airlocker rear axle FOR SALE [Re: Gravesdigger] #1072742 07/01/14 11:43 PM
Do you have the airpump/pressure regulator/release valve combo?
Re: Complete Montero SR Airlocker rear axle FOR SALE [Re: fasteddy] #1072743 07/02/14 04:07 AM
G
No I don't, but just bench testing the locker it only took between 10-15psi to actuate it. A guy I knew used a $15 fish tank pump to engage his. Or it should be easy enough to use a $4.75 HF regulator off another air supply on your vehicle. HF Regulator
offroading is fun
Re: Complete Montero SR Airlocker rear axle FOR SALE [Re: Gravesdigger] #1072744 07/04/14 10:38 PM
Mahoseph7 Offline
Any idea how much it would cost to ship to Fresno, CA? I Have no experience shipping heavy large items like this...how is ti done?
1991 Montero LWB V6 3.0 AT/ OME springs and coils Rear / Torsion crank Front / 33x12.50 BFG Muds
Upcoming Mods! Gen 2 Brakes up front / SR locked axle rear
Re: Complete Montero SR Airlocker rear axle FOR SALE [Re: Mahoseph7] #1072745 07/04/14 10:54 PM
Mahoseph7 Offline
And does anyone know of a place to find the yoke that mates up with the 1st gen drive-shaft?
Re: Complete Montero SR Airlocker rear axle FOR SALE [Re: Mahoseph7] #1072746 07/05/14 11:29 PM
it's been a while since i've done it but i think you just need to redrill the bolt holes for the V6 driveshaft, if it's 4 cylinder and you want to swap it in you will need to drill new holes then machine a recess into the side of the yoke to clear the washers.
Re: Complete Montero SR Airlocker rear axle FOR SALE [Re: TOASTY] #1072747 07/06/14 08:38 PM
I had an axle shop put the SR set up from the SR driveshaft on my Gen 1 driveshaft. The SR has bigger u-joints. Actually kept everything to see if I can go with the SR front set-up on mine, the u-joints are a lot beefier.
Re: Complete Montero SR Airlocker rear axle FOR SALE [Re: Gravesdigger] #1072748 07/07/14 04:59 PM
JoeBurt Offline
Sent a PM!
Re: Complete Montero SR Airlocker rear axle FOR SALE [Re: JoeBurt] #1072749 07/07/14 07:38 PM
G
I have shipped a bunch of axle before and the best way is to ship them freight: Strapped to a pallet.
I sent you a shipping quote.
Sent a PM!
PM Sent with shipping quote.
offroading is fun
Re: Complete Montero SR Airlocker rear axle FOR SALE [Re: Gravesdigger] #1072750 07/13/14 04:01 AM
G
bump
offroading is fun
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6362 MB (Peak: 0.7595 MB) Data Comp: Off Server Time: 2026-06-07 07:50:57 UTC
