What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP
#1073128
07/18/14 08:53 PM
What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP?
Re: What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP
[Re: tyty]
#1073129
07/18/14 09:01 PM
[Re: tyty]
#1073130
07/18/14 09:50 PM
What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP? Most everything...
[Re: tyty]
#1073131
07/19/14 04:12 AM
What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP? 90-91 are about the same although there may have been some minor tweaks. Haven't looked at the later engines since I was always after the 3.5L in the gen 2's.
[Re: JoeBurt]
#1073132
07/19/14 04:34 AM
1994 3.0 did get this yet came in 1996 I think
[Re: off-roader]
#1073133
07/19/14 05:45 AM
What change on Montero 3.0 engines from 1990 to 1994? 1990 = 143 hp ,1994 = 151 HP? 90-91 are about the same although there may have been some minor tweaks. Haven't looked at the later engines since I was always after the 3.5L in the gen 2's. Just trying to get more power out of Phi's gen 1
[Re: tyty]
#1073134
07/21/14 07:39 PM
![[Linked Image]](https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-xap1/t1.0-9/1489214_10202299006111014_391805407_n.jpg) Here is a picture of both blocks side by side.
[Re: Jay Ayala]
#1073135
07/22/14 04:59 PM
just try to get the 1990 up to 151 HP from 143 HP
[Re: tyty]
#1073136
07/22/14 07:55 PM
Usually horsepower changes like this are from better castings on intake manifolds, larger port sizes, maybe slightly different ignition/ fuel maps. Maybe different grade of fuel used for testing. I would look at upping torque more than horsepower.
[Re: JoeBurt]
#1073137
07/24/14 05:55 AM
web page A discussion about the 3.0 from a long time ago. My take... Later years had small improvements in the intake and fuel injection system. Engine Manual
