95 not charging need some help #1073227 07/26/14 01:58 AM
brubren3815 Offline OP
Jumped my 95 in the dark a few days ago and was a dumba-- and hooked the leads up wrong. <img src="/forums/images/graemlins/mrt.gif" alt="" />
Tried to crank it a couple of times that way but it would not start.(Duh). Fixed my mistake tried again and it started up fine. When I disconnected the neg cable,the truck ran for a minute or so, chugged and then stopped. As long as I left the 02's cables hooked up all was good. Saw no charging activity on my gauge. Looked at the big links in the fuse box by the battery and they looked ok.(how do you get those things out anyway?) Am I missing something? Did I kill the alt?
Help please
2002 XLS /LSD/Thule Rack /PIAA Extreme White headlamps /K+N system/Michelin LTX MS--KYB gas-adjust all around
95 LS-- Dual Bouncy Seats 234k and still rockin'
Re: 95 not charging need some help [Re: brubren3815] #1073228 07/26/14 03:06 AM
Have both the alternator and the battery tested. You may have done them both in.
Re: 95 not charging need some help [Re: JohnnyBfromPeoria] #1073229 07/26/14 04:29 AM
BottomFeeder Offline
Agreed. Probably not "may have". <img src="/forums/images/graemlins/cheers.gif" alt="" />
1990 Montero LS "Bottom Feeder" LWB, 33's, Cheapass Lift, 2" body lift, Dual BoUnCyS, Dual LSD's, KC's.
1995 Montero SR Complete LS interior swap and a BoUnCy from a 96 SR. General Grabber AT2's 33X12.5. 1.5" Body Lift
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5939 MB (Peak: 0.6475 MB) Data Comp: Off Server Time: 2026-06-10 02:53:54 UTC
