95 Can't open rear hatch #1073588 08/09/14 05:59 PM
brubren3815 Offline OP
Can't get in the rear hatch. The handle just acts as if it is locked all the time. Even tried the inside handle.
Is there a way to take off the inside panel to get access without opening the door?
Thanks!
2002 XLS /LSD/Thule Rack /PIAA Extreme White headlamps /K+N system/Michelin LTX MS--KYB gas-adjust all around
95 LS-- Dual Bouncy Seats 234k and still rockin'
Re: 95 Can't open rear hatch [Re: brubren3815] #1073589 08/16/14 05:49 PM
Trying a different approach...
Is there any way to open the back hatch if both handles do not work?
Re: 95 Can't open rear hatch [Re: brubren3815] #1073590 08/17/14 02:53 AM
MarkG Offline
The outside latch on mine broke about9 months ago. The inside still opened with a bit of work.
Try removing the door mounted tool kit and the inside latch surround. You may be able to pop off the door panel. You can then slit the plastic behind the door panel. This should give you access to the latch assembly and linkage.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5930 MB (Peak: 0.6461 MB) Data Comp: Off Server Time: 2026-06-13 14:10:01 UTC
