Is there an easy fix for very slow or non-flashing turn sugnals? #1073815 08/19/14 02:20 PM
sasnydley Offline OP
Anyone have a sipmple way of fixing this? I am not real aure if a new flasher or that it is even possible to get flashers? BTW where are the flashers?
Re: Is there an easy fix for very slow or non-flashing turn sugnals? [Re: sasnydley] #1073816 08/19/14 02:41 PM
lordtrunks Offline
the flasher relay is a common part its in the driver side kick panel toward the firewall turn the signal on with your head and a free hand listen and feel around for the click and thats the flasher relay. only thing that sucks about the after market relays is they are round and don't have a mounting bracket so you gotta tape/strap it to the harness or try the dealer for one not sure if you can get an oe anymore.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Is there an easy fix for very slow or non-flashing turn sugnals? [Re: lordtrunks] #1073817 08/19/14 03:12 PM
Okay . Hard part is getting it to flash... LOL
Re: Is there an easy fix for very slow or non-flashing turn sugnals? [Re: sasnydley] #1073818 08/19/14 10:01 PM
lordtrunks Offline
if you havn't found it yet, here
Re: Is there an easy fix for very slow or non-flashing turn sugnals? [Re: lordtrunks] #1073819 08/20/14 06:50 PM
Great pic! No I haven't had a chance to look yet. On last couple classes for my BSN (took me 20 yrs!)But I certainly need to look...
Re: Is there an easy fix for very slow or non-flashing turn sugnals? [Re: sasnydley] #1073820 08/21/14 01:17 AM
If the signals are flashing slow, the flasher is bad or the load is too low, like some bulbs are burned out or have a bad connection. The opposite happens when you hook up a trailer - the extra load makes the flashing too quick. Get it going and walk around the truck...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6118 MB (Peak: 0.6813 MB) Data Comp: Off Server Time: 2026-06-13 10:09:16 UTC
