I need a distributor plug
#1073919
08/27/14 01:05 AM
I need a distributor plug for a 1990 3.0 montero. It's the 4 wire rectangle one. I can't find one anywhere around here.
1990 SWB 3.0
Re: I need a distributor plug
[Re: crazyhal]
#1073920
08/27/14 08:37 AM
I don't have but clearify,,,the plug at firewall or plug at distributor?
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: KrzyDav]
#1073921
08/27/14 01:35 PM
My montero only has one distributor in front of engine.
1990 SWB 3.0
[Re: KrzyDav]
#1073922
08/28/14 08:01 PM
I don't have but clearify,,,the plug at firewall or plug at distributor? We know there's only one distributor, but Dave is asking which end of the harness you need the plug for, the end at the distributor or the end that is at the firewall? John B.
[Re: crazyhal]
#1073923
08/29/14 04:58 PM
I need a distributor plug for a 1990 3.0 montero. It's the 4 wire rectangle one. I can't find one anywhere around here. The plug on the firewall has 7 wires and is square he stated he is looking for a 4 wire plug that is rectangular like the one that plugs into the distributor. crazyhal if you can't find a plug can you repair the one you have by wiring new pins for it? Otherwise I would contact one of the places online that sell used engine wire harnesses.
1990 LWB RS A/T 1990 LWB Base A/T 1991 LWB LS A/T Going...Going...
[Re: danz91crx]
#1073924
08/30/14 07:13 AM
I need a distributor plug for a 1990 3.0 montero. It's the 4 wire rectangle one. I can't find one anywhere around here. The plug on the firewall has 7 wires carefull,,,the plug with 7 wires at firewall is the injector harness on the '89. The distributor plug is mounted near the injector harness plug and has 4 wires...
[Re: KrzyDav]
#1073925
08/31/14 01:37 AM
My apologies, I did not realize the 89 and 90 were different. My 90 has only one plug there on the firewall for the efi. I just assumed you meant that one.
[Re: danz91crx]
#1073926
08/31/14 09:10 AM
unfortunately the '89 is unique on alot of things electronic. If you have another year and need the plug at the dizzy, one off a caravan would work(I'm fairly sure). I think stating 92 3.0 , there wasn't a plug for the injectors either at the firewall, and if you needed injector harness you have to buy the entire wiring harness.
[Re: KrzyDav]
#1073927
10/07/14 01:24 AM
sorry im just getting back. i cant re-pin plug cause i broke the plastic part. im having hell with my montero. no tach needle movement while cranking...reading code shows crank angle sensor bad on two different distributors. i broke distributor plug back pinning using easyautodiagnostics.com method. I tested control relay and checks good as per factory service manual.
1990 SWB 3.0
[Re: crazyhal]
#1073928
10/07/14 02:10 AM
Did you get new plugs...?
