Re: I can rebuild your turbo. [Re: fasteddy] #1074094 09/03/14 10:17 PM
Can you rebuild other turbos like a Borg Warner K03 turbo?
Re: I can rebuild your turbo. [Re: off-roader] #1074095 09/03/14 10:48 PM
87monty Offline OP
Yes I will service most stock to modified ball bearing turbos. repair times very but will be expedited.
To all that may be interested,
If your turbo is beyond repair, all I will charge you is return shipping of your unit. I do not believe in wasting my time or your hard earned money.
Thanks,
Jason <img src="/forums/images/graemlins/kewl.gif" alt="" />
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: I can rebuild your turbo. [Re: 87monty] #1074096 09/07/14 11:51 PM
JAVYPRO Offline
AWESOME!!!
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: I can rebuild your turbo. [Re: 87monty] #1074097 09/09/14 07:21 AM
mxmikie Offline
any turbo ??? how about a IHI RHB32 ??
sure can, its the same turbo as the narrow
bearing Rhb31. Is there any physical Damage to the turbo?
no physical Damage to the turbo just leaking oil into the exhaust side..... how much for a rebuild ???
Re: I can rebuild your turbo. [Re: fasteddy] #1074098 09/10/14 03:25 PM
87monty Offline OP
Jason, I don't know if I'd do business with somebody who can't finish a 2.4 swap in over a year... <img src="/forums/images/graemlins/evil.gif" alt="" /> You need to update that post.
the 14b is a very nice upgrade. The 12a puts out about 365cfm at 15psi, and the 14b blows well over 450 at the same pressure. That means the 12a peaks out at about 240hp and the 14b at around 300+, using 1.5cfm/hp as a rule of thumb...
Eddy,I Updated the Post on what the hold up is, (engine Management)
As for the 14B , I am after all the used ones I can find including the Jdm 13A turbo. It will be a great upgrade option for many.
96 SR
Re: I can rebuild your turbo. [Re: mxmikie] #1074099 09/10/14 03:38 PM
87monty Offline OP
PM Sent.
96 SR
Re: I can rebuild your turbo. [Re: 87monty] #1074100 09/24/14 02:33 AM
87monty Offline OP
Hi guys here is my website(still in the site building process, but functional.
http://turbotechservice.com/
96 SR
Re: I can rebuild your turbo. [Re: 87monty] #1074101 09/24/14 04:10 PM
dannytuned Offline
I'll keep you in mind if I ever get to my DSM transaxle buggy, need the 14b freshened.
2001Sport 3.0-Headers-Cage-RoofChop-NP231/D300-D44/ARB-Ford9/Yukon/3Link-37's+H1's-PSC Assist-108:1
Re: I can rebuild your turbo. [Re: dannytuned] #1074102 09/24/14 10:08 PM
87monty Offline OP
Great just let me know, ill give you the best deal I can <img src="/forums/images/graemlins/kewl.gif" alt="" />
96 SR
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6356 MB (Peak: 0.7568 MB) Data Comp: Off Server Time: 2026-05-30 01:20:22 UTC
