Page 3 of 3 1 2 3
Re: My son bought a car and went against all my sensible teachings! [Re: ryany] #1074401 10/04/14 05:25 AM
BottomFeeder Offline OP
You were expecting the brake rotors to come with new bearing races? Is there something wrong with the existing bearing races that would make you want to replace them?
I just assumed it came as a whole assembly?
Re: My son bought a car and went against all my sensible teachings! [Re: BottomFeeder] #1074402 10/04/14 08:45 PM
Bearings and races come as a matched set, and must be kept that way. Races are a semi press fit in the hub, and have to be driven out with a drift. The disc hat is bolted to the hub and loctite is used, so they are a LOT of fun to get loose, unless you have a good vice handy. You also need a grease seal which drives in the back side of the hub bore.
If your disc is loose from the hub, you should take it apart and retighten the bolts with loctite. I have found that if you don't use loctite, the high freq squeal and viration works the bolts loose.
Re: My son bought a car and went against all my sensible teachings! [Re: fasteddy] #1074403 10/04/14 10:12 PM
Just to be clear, I'm talking about the Conquest rotors.
Re: My son bought a car and went against all my sensible teachings! [Re: BottomFeeder] #1074404 10/04/14 11:40 PM
Yes, I know. I've been looking at my starquest manuals.
Re: My son bought a car and went against all my sensible teachings! [Re: fasteddy] #1074405 10/05/14 12:24 AM
87monty Offline
Good looking car!!
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: My son bought a car and went against all my sensible teachings! [Re: 87monty] #1074406 10/09/14 12:28 AM
After measuring, pondering, measuring, getting distracted and measuring some more, I figured out that the wheel studs are too long for the lug nuts the PO put on them. I installed new bearings, races and rotors. Purchased some new basic lug nuts and everything works wonderfully. Thank you for all the help. I will have more questions soon.
Rich <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6211 MB (Peak: 0.6925 MB) Data Comp: Off Server Time: 2026-05-29 14:42:18 UTC
