Re: started new rebuilt 3.0 up for 1st time. [Re: haztoys] #1074577 10/17/14 02:40 AM
KrzyDav Offline OP
I'm stuck in CA, probably die here, ,,can't leave withoput transportation, and I'll probably die of starvation because I can't even afford cat food(to eat) on Soc. Sec. and it's 1.5 % cost of living. Enough ABOUT TH.
plugs are new,,careful not to get anti seeze on electrodes,,,I can't drive it now because the Cop says he'll impound me next time,,so no steam cleaning plugs..
The miss is real irregular and inconsistent at idle and thru rpms. Like an old jeep with wet cap. Nothings wet.
dave h.
Re: started new rebuilt 3.0 up for 1st time. [Re: KrzyDav] #1074578 10/21/14 12:52 AM
KrzyDav Offline OP
Well I don't feel as stupid today about the fear I might have screwed up my new engine..."the Radiator cap incedent"...
When I intended to turn that raditor cap 1/4 turn to blow coolant over to res.,,,and it easily went "too far",,blowing 3/4 gallon of coolant out from under cap.
This morning I opened cold to check coolant,,and Radiator cap turn fully off with almost no resistance...................
The little safety teeth on radiator snout are worn off,,,that's why I screwed up so easily.
I need to pull plugs yet and see their condition and if they tell something,,,frankly been to sick of this thing to do any work on it right now <img src="/forums/images/graemlins/barf.gif" alt="" />, maybe I should do compression check?
dave h.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5964 MB (Peak: 0.6448 MB) Data Comp: Off Server Time: 2026-05-29 14:32:50 UTC
