Timing belt snapped on '00 #1074630 10/06/14 03:03 PM
F
Fujisawa_Rob Offline OP
Am I screwed? Valve damage?
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: Timing belt snapped on '00 [Re: Fujisawa_Rob] #1074631 10/06/14 03:53 PM
cheesegrater Offline
From AGCO automotive website: Mitsubishi 3.8L Interference
Re: Timing belt snapped on '00 [Re: Fujisawa_Rob] #1074632 10/06/14 07:28 PM
monte3 Offline
The 3.5 engine is an interference engine, BUT if you're lucky there may not be any damage. Any loud metal against metal sounds? <img src="/forums/images/graemlins/confused.gif" alt="" />
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
Re: Timing belt snapped on '00 [Re: Fujisawa_Rob] #1074633 10/07/14 11:07 PM
P
pcc Offline
I had a interference Honda engine snap a timing belt. Bent a couple of valves but nothing else. Replaced two valves and on the road again.
You'll only know if you remove the head. Compression test first would be good idea.
Re: Timing belt snapped on '00 [Re: pcc] #1074634 10/08/14 02:24 AM
I would not do a compression test. A valve may be stuck extended, and you could do more damage. What speed was the engine at when the belt broke? This will give you an idea of how much damamge was done.
Ultimately, you'll have to pull at least one head, probably both, before you know what it's going to cost.
Re: Timing belt snapped on '00 [Re: fasteddy] #1074635 10/08/14 11:44 AM
Could he loosen the cams, replace the belt, THEN do compression test?
Re: Timing belt snapped on '00 [Re: cheesegrater] #1074636 10/08/14 07:13 PM
Possible, with great care. You have to rotate the motor so all pistons are below tdc, then rotate the cams by hand to be sure all valves are fully closing (very slim possibility they will). If you get very lucky, then you could put on a new belt and check compression. The problem is that a bent vavle will usually not fully close. A bent valve is the most probable result of a broken belt, followed by piston and head damage. Valves are steel. Pistons are aluminum. You can get piston damage ranging from just dents to broken piston crowns.
Re: Timing belt snapped on '00 [Re: fasteddy] #1074637 10/08/14 09:23 PM
I also just had a thought that maybe by loosening the cams and relieving the lobe pressure, one could detect a bent valve since it would not return to fully closed position.
Re: Timing belt snapped on '00 [Re: cheesegrater] #1074638 10/08/14 10:58 PM
You don't need to loosen the cams. Just rotate the crank so no piston is at tdc, then rotate the cam sprocket. You don't have to drop the piston much. Valve lift is under 3/4" max, even with the rocker ratio being over 1.
Re: Timing belt snapped on '00 [Re: pcc] #1074639 10/27/14 08:10 PM
F
Sorry for the delay, never got notifications of replies.
I'm in the process of pulling the heads, which of course means removing the whole top end. Kind of a pain. I'll know soon how bad the damage is. If I have valve damage, I might just go pull a set of j/y heads.
It snapped while driving, doing about 45. I had no idea what had happened, it just wouldn't restart. Now I know what a sudden compression loss feels like.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6383 MB (Peak: 0.7616 MB) Data Comp: Off Server Time: 2026-05-30 19:02:04 UTC
