Re: Considering a 91 Montero LS (thoughts?) [Re: TOASTY] #1074724 10/17/14 09:56 PM
jdavis Offline
I like the contrast between the posts here and on Exportal, welcome to the Wire!
At least pics can easily be posted over there <img src="/forums/images/graemlins/lol.gif" alt="" />
95 Montero SR
33 x 12.50
Aussie Locker
OME Heavy Duty Coils & Torsion Bars
ARB Front Bumper
76" Trail Gear Rock Sliders
XRC-9.5K Winch
Re: Considering a 91 Montero LS (thoughts?) [Re: jdavis] #1074725 10/19/14 10:09 PM
Dartmouthbrian Offline OP
Thanks everyone, the input has been SUPER helpful.
Jon: Shall we go get it? <img src="/forums/images/graemlins/wink.gif" alt="" />
91 Montero RS
90 Montero base
Re: Considering a 91 Montero LS (thoughts?) [Re: Dartmouthbrian] #1074726 10/20/14 05:40 AM
jdavis Offline
I'm in !! <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
95 Montero SR
33 x 12.50
Aussie Locker
ARB Front Bumper
XRC-9.5K Winch
Re: Considering a 91 Montero LS (thoughts?) [Re: jdavis] #1074727 10/20/14 06:29 AM
AZRaider Offline
My guess, the heater core is leaking and the owner just let it go which resulted in overheating the engine and blowing the gasket. I'd check out the heater core.
But otherwise, can't go wrong with it for $500. Good find.
1987 Dodge Raider, 2.6L, manuel, bone stock with a whole lot of new and refurbished parts. Brought back from the dead after 12yrs.
Re: Considering a 91 Montero LS (thoughts?) [Re: AZRaider] #1074728 10/21/14 06:03 AM
Quick question, Can a Montero Gen II with a 3.5 easily tow the Gen I?
Can you tow it with a tow bar? If so, what settings? Neutral/Neutral?
Or would a tow dolly or a flatbed be better? If tow dolly would we need to undo the drive shaft?
Any help here would be amazing.
91 Montero RS
90 Montero base
Re: Considering a 91 Montero LS (thoughts?) [Re: Dartmouthbrian] #1074729 10/21/14 06:10 PM
Oso Offline
Tow bar should work. IIRC you'll need to disconnect the shaft at the rear axle. and make sure it is in 2wd.
Re: Considering a 91 Montero LS (thoughts?) [Re: Dartmouthbrian] #1074730 10/21/14 06:12 PM
You have to remove the driveshaft if you use a tow dolly, and you can not back up with a tow dolly. 12 & 14mm combo wrenches and a ratchet strap to tie it up (with forward tension to hold it in the tcase) are all you need. The a/t has no neutral position in the tcase (or at least, no detent for neutral), and while it's possible to "balance" the shifter in a neutral position between 4hi and 4lo, any little bounce and it can drop into gear.
I think you can rent a flat bed trailer to haul it, which is what I would do.
Re: Considering a 91 Montero LS (thoughts?) [Re: fasteddy] #1074731 10/21/14 11:37 PM
So this Montero is a 5spd. To flat tow, would I still need to disconnect the driveshaft?
91 Montero RS
90 Montero base
Re: Considering a 91 Montero LS (thoughts?) [Re: Dartmouthbrian] #1074732 10/22/14 02:16 AM
plh Offline
T-Case in Neutral detent, Transmission in Neutral. Flat tow OK for 5 speed.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6326 MB (Peak: 0.7360 MB) Data Comp: Off Server Time: 2026-07-13 15:49:21 UTC
