Re: Considering a 91 Montero LS (thoughts?)
[Re: TOASTY]
#1074724
10/17/14 09:56 PM
I like the contrast between the posts here and on Exportal, welcome to the Wire! At least pics can easily be posted over there <img src="/forums/images/graemlins/lol.gif" alt="" />
95 Montero SR 33 x 12.50 Aussie Locker OME Heavy Duty Coils & Torsion Bars ARB Front Bumper 76" Trail Gear Rock Sliders XRC-9.5K Winch
[Re: jdavis]
#1074725
10/19/14 10:09 PM
Thanks everyone, the input has been SUPER helpful.
Jon: Shall we go get it? <img src="/forums/images/graemlins/wink.gif" alt="" />
91 Montero RS 90 Montero base
[Re: Dartmouthbrian]
#1074726
10/20/14 05:40 AM
Jon: Shall we go get it? <img src="/forums/images/graemlins/wink.gif" alt="" /> I'm in !! <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: jdavis]
#1074727
10/20/14 06:29 AM
My guess, the heater core is leaking and the owner just let it go which resulted in overheating the engine and blowing the gasket. I'd check out the heater core.
But otherwise, can't go wrong with it for $500. Good find.
1987 Dodge Raider, 2.6L, manuel, bone stock with a whole lot of new and refurbished parts. Brought back from the dead after 12yrs.
[Re: AZRaider]
#1074728
10/21/14 06:03 AM
Quick question, Can a Montero Gen II with a 3.5 easily tow the Gen I?
Can you tow it with a tow bar? If so, what settings? Neutral/Neutral?
Or would a tow dolly or a flatbed be better? If tow dolly would we need to undo the drive shaft?
Any help here would be amazing.
#1074729
10/21/14 06:10 PM
Tow bar should work. IIRC you'll need to disconnect the shaft at the rear axle. and make sure it is in 2wd.
#1074730
10/21/14 06:12 PM
You have to remove the driveshaft if you use a tow dolly, and you can not back up with a tow dolly. 12 & 14mm combo wrenches and a ratchet strap to tie it up (with forward tension to hold it in the tcase) are all you need. The a/t has no neutral position in the tcase (or at least, no detent for neutral), and while it's possible to "balance" the shifter in a neutral position between 4hi and 4lo, any little bounce and it can drop into gear.
I think you can rent a flat bed trailer to haul it, which is what I would do.
[Re: fasteddy]
#1074731
10/21/14 11:37 PM
So this Montero is a 5spd. To flat tow, would I still need to disconnect the driveshaft?
#1074732
10/22/14 02:16 AM
T-Case in Neutral detent, Transmission in Neutral. Flat tow OK for 5 speed.
- '83 Might Max: IG @83mmax
- '88 Raider: my OG
- '89 Raider: rescued
- '92 RS M/T: sold
- '93 SR: sent to crusher
- '05 Montero LTD: sold
- '18 PHEV: wife's daily
- '14 OL GT
- http://www.tuffpans.com
