Manual transmission crossmember #1075102 11/11/14 08:01 PM
P
Pablorok Offline OP
I swapped a3.4 into a 1990 2.8 V6 automatic trooper ,scraped the auto , and put in a MUA5 manual. I didn't know the crossmember was different, so I didn't get it with the trans. Now I can't find one. If anyone can sell me one , or point me in the right direction , I would greatly appreciate it . The whole project is stalled because of it. Any and all suggestions will be considered. cross reference info?
Re: Manual transmission crossmember [Re: Pablorok] #1075103 11/14/14 09:32 PM
Van Offline
You might try flipping the crossmember over or from side to side to see if the bolt holes will line up. Some Isuzus had the same crossmember with pre-drilled holes that were interchangeable for both autos and manuals... I just don't remember which models. <img src="/forums/images/graemlins/confused.gif" alt="" />
Check in the local junkyards for any V6 manual Troopers, don't get the crossmember from a 4 cylinder as it will not work.
You could also check ebay motor parts section (also check under Isusu, Izuzu and Izusu). <img src="/forums/images/graemlins/wink.gif" alt="" />
If you still can't find one, let me know and I maybe able to locate one.
'94 Isuzu Pickup, 4x4
NEVER give up...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5870 MB (Peak: 0.6349 MB) Data Comp: Off Server Time: 2026-07-09 13:34:29 UTC
