Page 2 of 3 1 2 3
Re: In search of a cheap set of 33's [Re: haztoys] #1075114 11/19/14 07:29 PM
I
IncorpoRatedX Offline OP
Hi Mr AM ..
Haztoys here ...Mountain Division AZ Crew .sir <img src="/forums/images/graemlins/patriot.gif" alt="" />..
You do know the biggest rat hole of Mitsz parts in the Southwest is up 'The Hill' here at top secret Junk-Yard X ?... But your AZCrew so I can get you what you need or come on up ... We got two hammered 4cly swb..Three Gen1 lwb and four Sports 3.0.. We have a 3.0 Sport very nice that has a nose job done to it ..So that was a running truck when someone stuffed it ..This lot has a few of the Gen1's with the crush right on top of them sorry to say ...
Good to have you here AM ...I am a wagon and strange little car lover too (English Ford Capri,,).. Looks if I got Toasty hooked too... <img src="/forums/images/graemlins/nana.gif" alt="" />
Have a good day
Caption Gear Box
Hazardous Toys inc
David,
Thank you for the offer! That's awesome, I will be happy to make the journey up, i might need to purchase a number of things from you, I've got a project that I'll be building next year and I'll need a lot of Frankenstein parts.
Let me know when it would be ok for me to come up, before I make the journey up 17 I'll need to change my rear shoes and fix my trailer brakes, My E350 "Ron Burgundy" is not making anymore mountain passes without working trailer brakes and new rear shoes. <img src="/forums/images/graemlins/lol.gif" alt="" />
speaking of cool little cars, here's the car we rescued over the last few days; my girlfriends 76, poor thing needs a bath and a new engine now. the 4G32 was on borrowed time, it leaked oil, burned oil, had been run dry a few times over the last few years, finally piston #3 soft seized in the cylinder and the toothpicks they call rod bolts let go, sending the rod cap into the side of the block and knocking a 2 inch chunk out of it. Little bugger still runs though, drove it onto the trailer!
V45W - 1999, 3.5 sohc, winter package
L042G- 1987, 2.6 carb, auto - Cylon Raider
A112 - 1973 Galant Wagon - 4G63 Turbo, 5 speed
L023G - 1983, 2.6 carb, 5 speed manual 4WD
L028 - 1983, 4D55 turbo diesel 2WD
Re: In search of a cheap set of 33's [Re: IncorpoRatedX] #1075115 11/20/14 03:27 AM
haztoys Offline
I'll be in and out of the county tell Jan I 'think' ... But come on up .. Let me know what the Frankenstein monster make up will be so I can see what comes are way ... Have some 4g63T parts to clean out if anyone needs them ...
Shocking how far some motors will go ... Got to run a Subaru 2.5 to the point of it almost saw its self in two ... <img src="/forums/images/graemlins/zombie.gif" alt="" />.. LOL... ROTFL... Never get to do that in my world ...But the owner of said 'Suby 2.5' said .. kill it or win .. ..LOL ...
Whats the plan for the 76 ...?
Re: In search of a cheap set of 33's [Re: haztoys] #1075116 11/20/14 04:23 PM
Put a date on the Calendar and i'll be there unless it's the same time as the winter camp out.
Re: In search of a cheap set of 33's [Re: TOASTY] #1075117 11/23/14 12:31 AM
I
Well, I thought I had everything;
Anyone local have a 2.6 automatic flexplate? Must have 6 bolt pattern for the torque converter (there's 4 and 3 bolt out there)
trying to get this thing up and running asap.
269.357.4372
-Josh
Re: In search of a cheap set of 33's [Re: IncorpoRatedX] #1075118 12/03/14 04:50 AM
I
5J's in new mexico had a flex plate. <img src="/forums/images/graemlins/evil.gif" alt="" />
header and no gizmo box carb looks good.
Re: In search of a cheap set of 33's [Re: IncorpoRatedX] #1075119 12/12/14 03:55 AM
I
Well, it's up and running and driving on the 2.6 that it used to have in it. Cleaned the crank threads all up and removed the broken bolts, it had the wrong crank bushing in it from when Mark (Runningbird) and his sons rebuilt the engine, one of the boys put the wrong bushing in and it was larger than the opening in the flex plate, flex plate was dished over the bushing and the flex plate wobbled over a 6 year span. The engine only has 4,000-6,000 miles on it according to Mark. I added a few mods during all that too.
has a 2 liter carb from a 76 Colt, with an open filter, running on 91, i may adapt the carb to a snorkle soon. Also has an unknown brand long tube header, 2 inch exhaust through a good flowing muffler, 3 row radiator, 1.5in body lift, 15x8 wheels and 33" tires. I bought a single boat heat extractor im going to fit to the passenger side of the hood to vent heat on slow trails. Also has a 120 watt 24" light bar for the front bumper.
Re: In search of a cheap set of 33's [Re: IncorpoRatedX] #1075120 12/12/14 03:19 PM
monte3 Offline
Josh, Good to see it up & running.
I was hoping to get to this one day, but...
Hopefully we'll see you, and the truck on the trail soon! <img src="/forums/images/graemlins/cheers.gif" alt="" />
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
Re: In search of a cheap set of 33's [Re: IncorpoRatedX] #1075121 12/12/14 07:16 PM
ryany Offline
Make sure you locate that vent far enough forward on the hood - too far to the rear and the high pressure area that develops at the base of the windshield while driving will actually push air back into the engine bay through the vent. Pressurizing the engine bay means that cooling air won't want to flow in through the radiator and you'll have created a serious problem with your cooling system - not something you need with a G54B.
95 Montero SR
Re: In search of a cheap set of 33's [Re: monte3] #1075122 12/12/14 10:21 PM
I
Hey it makes for a great budget rig for my girl while we get our feet on the ground here in AZ, this will work perfect until next year when I can afford to build up another SR chassis. I'm thankful it was available. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Will do, i bought a long narrow one with angled vents for that reason mostly, i'll also use the stock intake tube hook up to route a piece of ducting under the header pointed upwards to force air out of that vent while driving on the highway. <img src="/forums/images/graemlins/notooth.gif" alt="" /> hope it werks. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: In search of a cheap set of 33's [Re: IncorpoRatedX] #1075123 12/13/14 12:59 AM
haztoys Offline
<img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />....?
OK ...I'm confused ..But thats easy to do ...LOL..
So is this the RunningBirds Monty ...????
Where is the turbo motor ...?
Page 2 of 3 1 2 3
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6446 MB (Peak: 0.7569 MB) Data Comp: Off Server Time: 2026-06-22 07:33:15 UTC
