Re: Rebuild: throttle body gasket(s), 1989 V6
[Re: losduarte]
#1075142
11/26/14 05:53 PM
The heater plate isn't an emissions control device, it's for improved driveability in colder temperatures. CA might not make that distinction though, so you might end up having to keep in intact.
Yes, looping the hoses together to bypass the TB heater would be the way to do it, if you can get away with it.
95 Montero SR 3.8 MIVEC, Advance headers, 2 1/2" exhaust, Magnaflow muffler, OME shocks & rear springs, 2" body lift, 3" tank lift, 4.90s, TRE front locker, factory rear locker, Roger Brown Rock Sliderz, 315/75r16 (35") tires, Sport big brakes
[Re: KrzyDav]
#1075143
12/03/14 08:43 PM
I think we strayed a bit from topic.
Keep your H2o if it still works. I'd go ahead and replace ICS,,,can't hardly believe you still have an original. I've never had icing. I live at 1000 ft. el. Never iced on me up in The Sierra. Had an Opel Manta with Weber carb. In wet / frozen Ohio. Man, that thing formed an iceburge in the throat untill I invented a heated airfilter box.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: KrzyDav]
#1075144
12/05/14 05:14 AM
I dont understand the no heat plate deal ...I cant see where it would help to unhook it ... I have delt with icing up here at 6300ft on the AZ Highlands ...
Can you even buy a new '89' ICS..? ... I keep getting 90 ICS's on up in the box <img src="/forums/images/graemlins/confused.gif" alt="" /> ...I just reman the OEM three screw ICS...
[Re: haztoys]
#1075145
04/30/15 12:32 AM
Alright I made pattern and gasket material. Notice the way the heating unit has the grooves somewhat matching some of the openings on the throttle body. ![[Linked Image]](http://pic70.picturetrail.com/VOL1791/8671937/24603075/411182917.jpg) What about those 3 smaller holes on the edge of the throttle body? I made a pattern from which to cut the gasket material: ![[Linked Image]](http://pic70.picturetrail.com/VOL1791/8671937/24603075/411182918.jpg) Do I make an opening on the gasket for heat from the heating unit to make contact with air passing through those holes?
[Re: KrzyDav]
#1075146
05/05/15 08:09 PM
[Re: losduarte]
#1075147
05/05/15 08:40 PM
Can't you use some gasket maker sealer? ![[Linked Image]](http://www.autowares.com/images/product/PERMATEX/per-99070-400.jpg)
[Re: Jay Ayala]
#1075148
05/05/15 09:35 PM
I already have the pattern made and gasket material. What about those 3 small holes? Do they need to allow air to contact that heating unit? If so, then I will need to cut holes in the gasket material.
[Re: losduarte]
#1075149
05/05/15 10:20 PM
I already have the pattern made and gasket material. What about those 3 small holes? Do they need to allow air to contact that heating unit? If so, then I will need to cut holes in the gasket material. I've never had to deal with it before myself but maybe you can use a hammer and a set of sockets to cut the holes out of the gasket material? <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: off-roader]
#1075150
05/05/15 10:22 PM
I already have the pattern made and gasket material. What about those 3 small holes? Do they need to allow air to contact that heating unit? If so, then I will need to cut holes in the gasket material. I've never had to deal with it before myself but maybe you can use a hammer and a set of sockets to cut the holes out of the gasket material? <img src="/forums/images/graemlins/kewl.gif" alt="" /> Folks, do I NEED to make holes in the gasket to accommodate those 3 small holes? Yes or no.
[Re: losduarte]
#1075151
05/05/15 10:32 PM
Duarte, I'm not sure if you NEED the holes or not. But from every image I've researched on 1989 Dodge Raider 3.0L Throttle Body Gasket, those three holes do not appear.
Good luck.
